Re: 8.75 axle seals
[Re: roadhazard]
#1013314
06/14/11 04:27 PM
06/14/11 04:27 PM
Posts: 15,487 Florida
scratchnfotraction
![](/ubbthreads/images/graemlins/iagree.gif) seal spring to inside,pack the back side of the seal with some greese to help keep the spring from poping off whale you ![](/ubbthreads/images/graemlins/hammer.gif) them into place. sink them to the lip of the axle tube so they are in far enuff. good luck ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: 8.75 axle seals
[Re: ERAT340]
#1013315
06/14/11 04:50 PM
06/14/11 04:50 PM
Posts: 39 mi
ERAT340
mi
Re: 8.75 axle seals
[Re: scratchnfotraction]
#1013316
06/14/11 06:36 PM
06/14/11 06:36 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
good luck
Unless you are replacing the bearings the outer seals in the retainers are rarely messed with, they are mostly a dust and seal, keeping brake and road dust out of the seal are. worry mostly about the inner seals in the axle tube. When installing them making sure that they are in square install into the tube to the little step lip in the tube. They will stop when in far enough. Make sure that you clean, inspect and repack the bearings with a good grease before reassembly, this is the only lubrication that they should get. They are not lubricated from the rear end lube.
Re: 8.75 axle seals
[Re: MoparforLife]
#1013317
06/14/11 06:48 PM
06/14/11 06:48 PM
scratchnfotraction
OH! I was thinking the axle seals you mean the thin dust seals on the retainer and backing plate...DOOHH!!! should have paid more attention to what i was reading before typeing ![](/ubbthreads/images/graemlins/whistling.gif)
