Bananna grooving at home #1013265
06/14/11 01:26 PM
06/14/11 01:26 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Thought i read the other day someone asked bout banana grooving
At home. How would you do that and is it recommended on
Bushed rocker?
74 dart sport 440 www.Csucarbs.com
Re: Bananna grooving at home [Re: shoebox] #1013266
06/14/11 01:59 PM
06/14/11 01:59 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I did a set using a cut off wheel and an angle grinder. It's not brain surgery. Just put the shaft in a vise and work slowly.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Bananna grooving at home [Re: shoebox] #1013267
06/14/11 02:43 PM
06/14/11 02:43 PM
New York
polyspheric Offline
polyspheric  Offline
New York
All grooves will pass through the original oil hole at an angle to "wet" more of the rocker's internal bore.
The groove must end inside the rocker body in any position.
Boffin Emeritus
Re: Bananna grooving at home [Re: polyspheric] #1013268
06/14/11 03:02 PM
06/14/11 03:02 PM
organ
maximum entropy Offline
organ
i have did bannnaannnna gorving. it easy. really.
Re: Bananna grooving at home [Re: maximum entropy] #1013269
06/14/11 03:03 PM
06/14/11 03:03 PM
Guitar Jones Offline
i hav dun 8 the brown acid also.
Re: Bananna grooving at home [Re: Guitar Jones] #1013270
06/14/11 04:04 PM
06/14/11 04:04 PM
my own world
theraif Offline
theraif  Offline
my own world
Re: Bananna grooving at home [Re: Guitar Jones] #1013271
06/14/11 07:26 PM
06/14/11 07:26 PM
organ
organ
i have did this a swell.
Re: Bananna grooving at home [Re: maximum entropy] #1013272
06/15/11 05:22 PM
06/15/11 05:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I agree,it's easy. Just stop short of the outer edges of the rocker. Polish afterwards to remove any burrs. use the real thin cut off wheels.
Doug
Re: Bananna grooving at home [Re: dvw] #1013273
06/15/11 09:44 PM
06/15/11 09:44 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
ive got a dremel tool with the very thin paper discs... will that work? and how deep should i go?
Re: Bananna grooving at home [Re: shoebox] #1013274
06/15/11 10:50 PM
06/15/11 10:50 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
.020-.030",Try it and see if it cuts.
Doug
