Re: Bananna grooving at home
[Re: shoebox]
#1013266
06/14/11 01:59 PM
06/14/11 01:59 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
I did a set using a cut off wheel and an angle grinder. It's not brain surgery. Just put the shaft in a vise and work slowly.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: shoebox]
#1013267
06/14/11 02:43 PM
06/14/11 02:43 PM
Posts: 4,210 New York
polyspheric
New York
All grooves will pass through the original oil hole at an angle to "wet" more of the rocker's internal bore. The groove must end inside the rocker body in any position.
Boffin Emeritus
[Re: polyspheric]
#1013268
06/14/11 03:02 PM
06/14/11 03:02 PM
Posts: 5,080 organ
maximum entropy
organ
i have did bannnaannnna gorving. it easy. really.
[Re: maximum entropy]
#1013269
06/14/11 03:03 PM
06/14/11 03:03 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
i hav dun 8 the brown acid also.
[Re: dvw]
#1013273
06/15/11 09:44 PM
06/15/11 09:44 PM
Posts: 808 mckinney texas
shoebox
mckinney texas
ive got a dremel tool with the very thin paper discs... will that work? and how deep should i go?
