shake down with the Dart #1012919
06/13/11 10:46 PM
06/13/11 10:46 PM
sycamore,ohio
BobsProFab Offline OP
sycamore,ohio
thrashed to get the car ready for the small tire race in Ky
ran a shake down pass to make sure it went straight, trans shifted and i had brakes
foot braked it pretty much from an idle, laid it down part throttle shifting @ 6,600 rpm and let out just before the stripe.
5.86 with a 1.32 60 and 114mph
had a big smile on my face from that shake down pass
it still had almost 250 more HP from the dyno sheets from what it made at 6,600 rpm
now time to turn the thing up to lay a number down.
we pulled back up to the staging lanes, i fired it up and put it in gear to pull out and i hear a tining noise i shut it off as quick as i could
we pulled it back to silverfishs pit, only place we had light to see what went wrong.
i started pulling plugs out on the #1 side as Vic started pulling plugs on the other side.
he got to #2 cylinder and the plug was smashed
pulled the valve cover and #2 cylinder had dropped a exhuast valve
i pulled the head to see how bad it was
need a new piston, lucky the cylinder wall doesnt have a scratch in it
head isnt hurt very bad also
should be a easy fix then its time to turn this beast up
Bob
Re: shake down with the Dart [Re: BobsProFab] #1012920
06/13/11 10:47 PM
06/13/11 10:47 PM
sycamore,ohio
sycamore,ohio
pic of the head
Re: shake down with the Dart [Re: BobsProFab] #1012921
06/13/11 10:51 PM
06/13/11 10:51 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Bob,
I am glad it wasn't more damage than that!I had asked Vic to let me know how you were doing down there,sad to hear how it went.
Get her fixed and let her rip!!!!11
Keith
Re: shake down with the Dart [Re: Dunnuck Racing] #1012922
06/13/11 10:52 PM
06/13/11 10:52 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
What caused it???
Re: shake down with the Dart [Re: Dunnuck Racing] #1012923
06/13/11 10:53 PM
06/13/11 10:53 PM
Q
Quicktree Offline
Quicktree  Offline
Q
dam the bad luck, hope you get it fixed soon. it's going to be a beast
Re: shake down with the Dart [Re: BobsProFab] #1012924
06/13/11 10:54 PM
06/13/11 10:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bob, what do you figure happened
Re: shake down with the Dart [Re: Hot 340] #1012925
06/13/11 10:56 PM
06/13/11 10:56 PM
sycamore,ohio
sycamore,ohio
im sure it stressed out the valve from the dyno pulls
the first time on the pump i broke a few springs, replaced them and went back on the pump
total of 28 pulls on it at 10,000 rpm
thats racing, $hit happens !
Re: shake down with the Dart [Re: BobsProFab] #1012926
06/13/11 10:56 PM
06/13/11 10:56 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
That sucks, Bob. This is a used bullet, right? I would treat the motor like any roller motor, and pretend it's at it's 250 pass maintainence check. New roller lifters, new bearings, hone, new rings, zyglow the crank and rods, valve job and new springs and keepers. And since one valve died, I sure as h e l l wouldn't reuse any of the remaining 15. That's how I see it.
Re: shake down with the Dart [Re: MR_P_BODY] #1012927
06/13/11 10:58 PM
06/13/11 10:58 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Sorry to see that Bob Hope you get it done and show 'em how it's done!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: shake down with the Dart [Re: MR_P_BODY] #1012928
06/13/11 10:59 PM
06/13/11 10:59 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I would be curious to hear how old the valves were, or has the valve seized up in the guide possibly?
Alan Jones
Re: shake down with the Dart [Re: Leigh] #1012929
06/13/11 10:59 PM
06/13/11 10:59 PM
sycamore,ohio
sycamore,ohio
it will come completely apart to go over ever thing
im steping up on valve size also
these 6mm stems dont like any valve train funk !
Re: shake down with the Dart [Re: BobsProFab] #1012930
06/13/11 11:00 PM
06/13/11 11:00 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Sorry to hear about the carnage but the shake down pass looks promising. I really hope you get that small block Mopar into the Thompson Renegade 8.90 class this year.
Re: shake down with the Dart [Re: ProSport] #1012931
06/13/11 11:21 PM
06/13/11 11:21 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Bro if you need anything at all you just give me a shout!!! Ill do anything I can to help you out.
But......once this new trans of mine is done.... Just be ready for the $hit talking to resume.....
Oh, and I see the curiosity got the best of you.... Did you pull the whole motor or just the head.
Re: shake down with the Dart [Re: joshking440] #1012932
06/13/11 11:25 PM
06/13/11 11:25 PM
sycamore,ohio
sycamore,ohio
just the head to see how bad it was
you better turn your $hit up or this little 358 will eat that green turd for supper
Re: shake down with the Dart [Re: BobsProFab] #1012933
06/13/11 11:29 PM
06/13/11 11:29 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Damn Bob. That sucks.
But I know you'll be back soon and better than ever.
BTW.......
I found that trans mount in my shed
Re: shake down with the Dart [Re: WILD BILL] #1012934
06/13/11 11:38 PM
06/13/11 11:38 PM
ky
headhunter Offline
headhunter  Offline
ky
sorry to hear about the breakage your car is anawsome piece pictures do not do t justice
Re: shake down with the Dart [Re: BobsProFab] #1012935
06/13/11 11:49 PM
06/13/11 11:49 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Emerald bob, not green..... And don't you worry about the poor overweight street car, he will be just fine....
Re: shake down with the Dart [Re: BobsProFab] #1012936
06/13/11 11:52 PM
06/13/11 11:52 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Oh ha. Ha. Ha. Ha. Ha. Your car eats turds hahahahahaha
Re: shake down with the Dart [Re: joshking440] #1012937
06/14/11 12:06 AM
06/14/11 12:06 AM
Northern Indiana
Northern Indiana
Sorry,Bob,but I gotta agree with Josh on that one!
Keith
Re: shake down with the Dart [Re: Dunnuck Racing] #1012938
06/14/11 04:36 AM
06/14/11 04:36 AM
Oh
His and Her 69's Offline
Oh
Good Idea to tear it all down and check everything Bob.
My cyl looked Good and no marks from the dropped valve but upon complete teardown we found a crack in the cyl wall.
Take your Time and make sure all is GOOD before something bad happens from trying to rush it back together.
Sorry to hear about the motor though.
If I can Help any let me know.
David
