Newbie Help With Speedometer #1012737
06/13/11 03:25 PM
06/13/11 03:25 PM
London, England
JFChallenger440 Offline OP
London, England
Hi guys, just bought a 1971 Challenger, the speedo isn't working, could anyone give me a step by step guide of how I can diagnose the problem ? I assume the dials and dash need to come out? Please could you tell me how to remove the dash and dials to get to the cable, thanks a lot for any help
Re: Newbie Help With Speedometer [Re: JFChallenger440] #1012738
06/13/11 03:42 PM
06/13/11 03:42 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
pull the cable from the back of the gauge, and drive the car. (you should be able to go under the dash, and squeeze the clip at the back of the speedo, releasing the cable) is the end of the shaft turning? if not, pull it from the trans housing, and hold one end of the cable, and twist the other. if it spins, check the clocking of the drive, and make sure the gears not broken/missing in the trans. if it doesnt spin, you need a cable. if all of this works, make sure the cable is plugged in, and properly seated in the speedo gauge. if it doesnt work now, the gauge is likely bad. this all should take about 15 minutes, and a set of ramps, or jacks and jackstands, to access the side of the trans.
Re: Newbie Help With Speedometer [Re: Golden-Arm] #1012739
06/13/11 05:02 PM
06/13/11 05:02 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Just an easier way to check.Jack up car.Put stands under rear end.Have someone start car after you disconnect speedo from trans.See if gear in trans spins while in gear.Then attach drill to speedo cable and spin it from under car.Have someone watch speedo to see if it registers.Easier than trying to fight under the dash.I cant remember if the drill has to spin CW or CCW.Getting old.Rocky
Chrysler Firepower
Re: Newbie Help With Speedometer [Re: therocks] #1012740
06/13/11 09:32 PM
06/13/11 09:32 PM
Chilly Northern, Minn.
71 Charger R/T Offline
Set your drill to turn counter clockwise or you'll just be taking miles off the odometer.
Re: Newbie Help With Speedometer [Re: 71 Charger R/T] #1012741
06/13/11 10:00 PM
06/13/11 10:00 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Low mileage original baby!
Drill baby drill!
That's all I got.
Careful, your character's showing!
Re: Newbie Help With Speedometer [Re: 71 Charger R/T] #1012742
06/13/11 11:34 PM
06/13/11 11:34 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Nice try. You can NOT remove miles from these odometers.
Federal law dictated this "anti'tampering" feature long ago. The sppedo will not read in reverse either. Spin drill on reverse to get the speedo to read correctly.
Re: Newbie Help With Speedometer [Re: Kern Dog] #1012743
06/14/11 04:34 PM
06/14/11 04:34 PM
London, England
London, England
Thanks guys, i'm sure i'll have more questions soon, thanks a lot
