Page 3 of 4 1 2 3 4
Re: The good and BAD things the Ma MoPar engineers did .... [Re: mcmopars] #1012627
06/16/11 08:31 AM
06/16/11 08:31 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
bought a 61 that had flat tires because owner couldnt get the lugs off.he said they were on way too tight.but only on one side.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: The good and BAD things the Ma MoPar engineers did .... [Re: Kern Dog] #1012628
06/16/11 08:36 AM
06/16/11 08:36 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Wasn't there a model that had the battery hidden behind an inner fender?
Stratus for sure as I know from personal experience. I think the Intrepids and last FWD NewYorkers were too.
John
Re: The good and BAD things the Ma MoPar engineers did .... [Re: T2R9] #1012629
06/16/11 09:12 AM
06/16/11 09:12 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Bad - Neon head gaskets. someday I'd like to kick the genius in the nads,, who thought putting a rubber seal between an alumunum head and a steel block was a good idea. To make it worst offer less than 3 hours warrenty time to replace said screw up
the good - 3.3 water pumps. They are notorius to leak but at least there about as easy to replace as they can be.
Re: The good and BAD things the Ma MoPar engineers did .... [Re: gtx6970] #1012630
06/16/11 09:51 AM
06/16/11 09:51 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
There's always stuff but I'm happy with the 69, 06 and 09.
Re: The good and BAD things the Ma MoPar engineers did .... [Re: SattyNoCar] #1012631
06/16/11 11:51 AM
06/16/11 11:51 AM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
Yep, Sebrings too. I was stunned by the stupidity. Others have already mentioned the Small Bolt/big Bolt wheels, crimp on coupler, ampmeter are a few mess ups. How about non-standard gauge sizes, glove box door without a latch on a 67 a-body=step on gas and open glove box, some of the one year only features on my 67's suspension. Complex installation and removal of the rear side windows on my Barracuda mean it is more practical to put them in before the quarters are welded on. The flip side is almost everything is fixable or can be improved upon with a little ingenuity!!
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: The good and BAD things the Ma MoPar engineers did .... [Re: DennisH ] #1012632
06/16/11 11:51 AM
06/16/11 11:51 AM
Morningside
AdventurerSport Offline
waaaay out there in left field
Morningside
Amp gauges on 70s trucks, or how about keeping the same truck body style 72-93 but changing the body lines in 81 so that a 81-93 box will fit my 76 Power Wagon and work but not look right.
How bout using Mitsubishi engines well past the point of having our own very reliable line of 4 cylinder and V6 engines?
Diamond Star Motors...'nuff said.
2.2/2.5 timing belt design (non interference) Yay! Mitsu 4s, not so much...:(
3.6 Pentastar engine, yay! 2.7 sludge engine,
Oh, and, anyone else enjoy changing the oil filter on 3.7 Jeep Libertys 08-up? Ugh! Tight and difficult to see!
Which leads me to...who thought making Mopar oil filters BLACK was a good idea??
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: The good and BAD things the Ma MoPar engineers did .... [Re: AdventurerSport] #1012633
06/16/11 12:11 PM
06/16/11 12:11 PM
Morningside
Morningside
Speaking of Mitsu engines, why did they ever switch from the common 3.0L down to a 2.5L version and then back to the 3.0? 3.0 was very common in the early 90s, then mid 90s Avenger, Sebring, Eclipse went to the 2.5, then back to the 3.0 around 2001...?
Anyone ever notice Mitsubishi FWD drivetrains are backwards to ours? Chrysler uses an East-West arrangement, whereas Mitsubishi cars use a West-East style...(our engines sit with the front at the passenger side, their drivetrains face the drivers side)...meaning that, when we choose Mitsubishi as our Japanese partner, we couldn't even easily share powertrains.
Dodge Challenger...Imported from Japan, with the new 2.6L Hemi! Ugh!
I prefer my Mopar 10 imported from Canada with 5.7L Hemi!
JS
Re: The good and BAD things the Ma MoPar engineers did .... [Re: 383man] #1012634
06/16/11 12:35 PM
06/16/11 12:35 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Here is a good one many may not know. But on the old reduction gear starters when I would rebuild them Ma put a washer on end of the armature where the brushes go with 4 bent legs on it. It worked great when assembling the starter as the washer would hold the 4 brushes in place so you could slip the armature right in and the brushes would fall in place against the armature when it pushed the washer out. It really made it much easier when assembling it. Ron
Once you figured out (read somebody told you) why that washer had those goofy legs on it.
Kevin
Re: The good and BAD things the Ma MoPar engineers did .... [Re: dOoC] #1012635
06/16/11 05:31 PM
06/16/11 05:31 PM
WA
GasHog72 Offline
GasHog72  Offline
WA
Bad: 80's 2.2L/2.5L engines were junk. First big thing to go...the main bearings. Caravans, Shadows you could hear the rod banging around in most after 100,000 miles. They also had the stupid idea of putting the ECU wiring harness by the battery which resulted in the wiring getting corroded from the battery acid which caused random shutdowns and bare wires. 2003-2004 stratus has a horrible dash problem with the outer vinyl layer just peeling right off when exposed to defrost heat and sunlight. The rear disc brakes are not so easy to get off. They are held in place by something INSIDE the rotor like a drum. Never did get the back discs off. Never found out why the adjuster didn't let me remove it. Glad I sold it.
Good: Early 60's body styling.
Re: The good and BAD things the Ma MoPar engineers did .... [Re: GasHog72] #1012636
06/17/11 12:36 AM
06/17/11 12:36 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The 2.2 & 2.5 were know for piston pins getting loose and knocking. Had to replace the pistons to correct. Lost count of how many I did. Ron
Re: The good and BAD things the Ma MoPar engineers did .... [Re: 383man] #1012637
06/17/11 07:23 PM
06/17/11 07:23 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Bad: After 78', NO MORE big block Mopar Engines being factory built, so they did not catch the "fuel injection" technology directly, as the small block and the HEMI (Gen 3) did.
Good: Big blocks keep growing in displacement, as well as the aftermarket SHOWERING them with so much
parts and equipment, it's mind boggling!! Just wish they would come-up with a Max-Wedge (port sized) intake for the B' engine!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: The good and BAD things the Ma MoPar engineers did .... [Re: HYPER8oSoNic] #1012638
06/18/11 10:51 AM
06/18/11 10:51 AM
Morningside
Morningside
To the guy that mentioned the rear brake rotor that was held on like a drum...the something inside was the parking brake, which works just like drum brakes on the inside of the rotor "hat". Not really a Mopar thing, at least, not exclusively...they are all pretty much that way now.
JS
Re: The good and BAD things the Ma MoPar engineers did .... [Re: AdventurerSport] #1012639
06/18/11 10:57 AM
06/18/11 10:57 AM
Morningside
Morningside
My 2010 Jeep Liberty only has 1 factory power outlet! One!! Making it just as convenient and advanced as my 76 Power Wagon! (albeit at a drastically increased price)...!
That's just stupid. Liberty platform gets NO upgrades as it's due to be replaced soon, but that means no MyGig radios for Libertys! ??
Wife is looking to upgrade her ride, may end up with a new Compass which has MyGig, two power outlets, and better fuel economy. Sheesh, other than the difficult oil change and the above issues, she really like the Liberty. I would've traded up to a newer Liberty with the Pentastar engine, but that's not coming, either, so Liberty buyers are stuck with the 3.7 engine (standard and ONLY engine in the Liberty)
JS
Re: The good and BAD things the Ma MoPar engineers did .... [Re: AdventurerSport] #1012640
06/18/11 11:46 AM
06/18/11 11:46 AM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
Bad- Internal water pump in th 2.7L and special tooling required to bleed air out of the coolant system.
Randy
Re: The good and BAD things the Ma MoPar engineers did .... [Re: AdventurerSport] #1012641
06/18/11 12:22 PM
06/18/11 12:22 PM
Kirkland, Washington
Pacnorthcuda Offline
JS
Adventurer; What is wrong with a black oil filter?
Re: The good and BAD things the Ma MoPar engineers did .... [Re: Pacnorthcuda] #1012642
06/18/11 01:28 PM
06/18/11 01:28 PM
Desert Tracker
Desert Tracker
JS
Whats wrong with 'em "Good guys (motors) wear black", quote on a Chuck Norris flick with a twist. I like the
black filters because of the greasy prints left on those orange and white filters, removing and installing them! Don't have to keep cleaning them.
Re: The good and BAD things the Ma MoPar engineers did .... [Re: HYPER8oSoNic] #1012643
06/18/11 05:45 PM
06/18/11 05:45 PM
Tulsa oklahoma USA
2
2734bbl Offline
2734bbl  Offline
Tulsa oklahoma USA
mid 90's to early 2000's 2.5L Stratus,Sebring(coupe and convertable are 2 different cars completely,but both junk)and Cirrus were complete catastrophies.
I'd like to meet the guy who designed the K frame on those cars and the guy who came up with the cooler line check valve on the trucks and Jeeps with about 2 feet of 5/8 heater hose handy.
01-05 minivan rear trans(firewall side) mount and lower ball joint stud with BOTH a lock nut and blue lock tight and you cant screw it all the way off without pushing the CV axle back.As a matter of fact most every bolt below the skin on these has locktight.Blower motor resistor on these...well...um... they blow...
Goofy cooling system on the early Cherokees with the bottle by the firewall.Upper rear shock bolts on these are dreadfull also
Dashes on 94-01 trucks...
I still wish I knew why Chrysler was obsessed with a different bellhousing pattern or trans case for each engine or platform.The same motor and trans in a truck and jeep but the starter is on opposite sides and uses a diffrent starter.
Re: The good and BAD things the Ma MoPar engineers did .... [Re: 2734bbl] #1012644
06/19/11 11:38 PM
06/19/11 11:38 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
The bad: Late 90s and up Grand cherokee cooling fan relay placement.
Power transfer units on AWD Journeys, GETRAG produced, need I say more. The new 62TE FWD auto transmissions. What a POS.
The good: The vehicles they produce are generally easier to work on than the other brands.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: The good and BAD things the Ma MoPar engineers did .... [Re: Pacnorthcuda] #1012645
06/20/11 08:44 PM
06/20/11 08:44 PM
Morningside
Morningside
JS
On the Liberty, the oil filter is very hard to see, and in black, it blends right in with the suspension. That's about it...white Napa Gold filters are much easier to see/find when changing the oil...that's all.
JS
Re: The good and BAD things the Ma MoPar engineers did .... [Re: dOoC] #1012646
06/21/11 12:52 AM
06/21/11 12:52 AM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
Bad: so many different K frames, bellhousing patterns, engine mounts...the only time I envy a GM guy is when they take a 250 inline 6 and bolt a 454 to it. Too easy.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Page 3 of 4 1 2 3 4
