Banana grooved rocker shafts #1011756
06/12/11 11:33 AM
06/12/11 11:33 AM
pacific northwest
W
wings471 Offline OP
wings471  Offline OP
W
pacific northwest
I went on Hughes site this morning to order a set of these banana grooved shafts and there is no listing for the shafts by themselves, only in kit form. Do any of you have some recommendations for a great oiling shaft to use with a 440-1 street/strip motor making 600-700 hp ? Thanks for the help.
Re: Banana grooved rocker shafts [Re: wings471] #1011757
06/12/11 03:08 PM
06/12/11 03:08 PM
Redding,CA USA
440charger500 Offline
Redding,CA USA
I would check with Rocker Arm Specialists in Anderson,CA. They do great work.
Re: Banana grooved rocker shafts [Re: wings471] #1011758
06/12/11 03:19 PM
06/12/11 03:19 PM
Not what you requested but an option would b to groove a primo set w a hacksaw blade then take down the slight burr on the edges w just the right grit, not rocket science just spreads the film. Seperate issue but I also externally oil the heads like Indy does horizontally thru the rear to/angle up to the #5 pedestal. that lets me elim the cam bearing massive oil leaks (reduce each cam bearing vertical feed to 1/16")
Re: Banana grooved rocker shafts [Re: RapidRobert] #1011759
06/12/11 03:28 PM
06/12/11 03:28 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Like Robert said it isn't rocket science. Use a dremel tool and cut your own.
Re: Banana grooved rocker shafts [Re: wings471] #1011760
06/12/11 05:56 PM
06/12/11 05:56 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
didnt MP sell in thier catalogue before or did they stop?
Re: Banana grooved rocker shafts [Re: moparsquid] #1011761
06/13/11 02:16 AM
06/13/11 02:16 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Did you call Hughes and ask about the rockers shafts? I'll bet they will sell you some if you call and ask.
Re: Banana grooved rocker shafts [Re: bobby66] #1011762
06/13/11 02:50 AM
06/13/11 02:50 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I know I just bought the Hughes rocker shaft hold down hardware kit a few weeks ago. My brother made me a deal on Hughes rockers (1.6 rollers) and shafts that were like new so I bought the hughes hold down hardware. I thought they sold the shafts seperate but I may be wrong. I would call and ask just to be sure as it cant hurt and I like their products. Ron
