Re: Banana grooved rocker shafts
[Re: wings471]
#1011758
06/12/11 03:19 PM
06/12/11 03:19 PM
RapidRobert
Not what you requested but an option would b to groove a primo set w a hacksaw blade then take down the slight burr on the edges w just the right grit, not rocket science just spreads the film. Seperate issue but I also externally oil the heads like Indy does horizontally thru the rear to/angle up to the #5 pedestal. that lets me elim the cam bearing massive oil leaks (reduce each cam bearing vertical feed to 1/16")
[Re: bobby66]
#1011762
06/13/11 02:50 AM
06/13/11 02:50 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I know I just bought the Hughes rocker shaft hold down hardware kit a few weeks ago. My brother made me a deal on Hughes rockers (1.6 rollers) and shafts that were like new so I bought the hughes hold down hardware. I thought they sold the shafts seperate but I may be wrong. I would call and ask just to be sure as it cant hurt and I like their products. Ron
