Best source for wiring electric choke? #1010924
06/11/11 10:28 AM
06/11/11 10:28 AM
Milwaukee, WI
Prince_Valiant Offline OP
Milwaukee, WI
Where have you guys sourced your power for the electric choke? I'm new with having an electric choke and can certainly come up with a bunch of "it'll work" ideas...but what's *the best* route generally?
tia,
chris
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: Best source for wiring electric choke? [Re: Prince_Valiant] #1010925
06/11/11 11:19 AM
06/11/11 11:19 AM
The blue (ign1) wire that runs along the inner side of the pass valve cover to the alt field. T into it right there at the choke. You may need to run it thru a resistor in series first such as the white OE choke resistor piece if it comes off 2 quick but this'll get you started
Re: Best source for wiring electric choke? [Re: Prince_Valiant] #1010926
06/11/11 03:30 PM
06/11/11 03:30 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
We usually connect the electric choke lead to the 12V input of the ballast resistor..
Just my $0.02...
Re: Best source for wiring electric choke? [Re: Sinitro] #1010927
06/11/11 05:33 PM
06/11/11 05:33 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
Just my $0.02...
I do that also...some "professionals" don't agree with it but I never had any problems on several cars over 4 decades.
Re: Best source for wiring electric choke? [Re: terzmo] #1010928
06/11/11 06:09 PM
06/11/11 06:09 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Like this.
Re: Best source for wiring electric choke? [Re: 62maxwgn] #1010929
06/11/11 07:59 PM
06/11/11 07:59 PM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
thats the source factory TOOK to source it!, but being an splice from the wire feeding the second alt field on dual field alts, which is the same net, than the one what feeds the ballast.
