Best source for wiring electric choke?
#1010924
06/11/11 10:28 AM
06/11/11 10:28 AM
Posts: 1,665 Milwaukee, WI
Prince_Valiant
Milwaukee, WI
Where have you guys sourced your power for the electric choke? I'm new with having an electric choke and can certainly come up with a bunch of "it'll work" ideas...but what's *the best* route generally?
tia, chris
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph 1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD) 1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD) 1989 Shelby CSX #500/500
Re: Best source for wiring electric choke?
[Re: Prince_Valiant]
#1010925
06/11/11 11:19 AM
06/11/11 11:19 AM
RapidRobert
The blue (ign1) wire that runs along the inner side of the pass valve cover to the alt field. T into it right there at the choke. You may need to run it thru a resistor in series first such as the white OE choke resistor piece if it comes off 2 quick but this'll get you started
#1010926
06/11/11 03:30 PM
06/11/11 03:30 PM
Posts: 5,444 So Cal
Sinitro
So Cal
We usually connect the electric choke lead to the 12V input of the ballast resistor.. Just my $0.02...
[Re: Sinitro]
#1010927
06/11/11 05:33 PM
06/11/11 05:33 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
Just my $0.02...
I do that also...some "professionals" don't agree with it but I never had any problems on several cars over 4 decades.
[Re: 62maxwgn]
#1010929
06/11/11 07:59 PM
06/11/11 07:59 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
thats the source factory TOOK to source it!, but being an splice from the wire feeding the second alt field on dual field alts, which is the same net, than the one what feeds the ballast.
