What's your trick for removing wiper arms from the post #1010713
06/10/11 09:15 PM
06/10/11 09:15 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
What's your trick for removing the wiper arms from the wiper post? I have a couple of stubborn wiper arms on my '69 GTX and for the life of me can't figure them out. I'm affraid that I'm going to mess up the hood stripes but they won't come off of the posts like they have on other cars without prying or .......... so I just walked away before I did something stupid....any tricks or what the heck am I doing wrong this time? Thanks
MikeR
Re: What's your trick for removing wiper arms from the post [Re: A12] #1010714
06/10/11 09:20 PM
06/10/11 09:20 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
I have a wiper arm removing tool. You should be able to get on at your local automotive parts store , Napa, Carquest..etc.
You can also buy them on eBay.
Re: What's your trick for removing wiper arms from the post [Re: GLR] #1010715
06/10/11 09:27 PM
06/10/11 09:27 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Which one? I did a search for a wiper arm removal tool and it seems there's more than one type and application.........even one just for Corvette's (but I think that's like ebag ads that say "for Hemi's and A12's" so the $$$$$ goes up 50%" )
Re: What's your trick for removing wiper arms from the post [Re: A12] #1010716
06/10/11 09:40 PM
06/10/11 09:40 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
Re: What's your trick for removing wiper arms from the post [Re: A12] #1010717
06/10/11 09:42 PM
06/10/11 09:42 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I was told not to be a wuss and just pry when I asked so I did. I put stuff to protect the metal, pryed, and pop!
Ride eternal, shiny and chrome
Re: What's your trick for removing wiper arms from the post [Re: DirectSubjection] #1010718
06/10/11 09:47 PM
06/10/11 09:47 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
Well, I have done that too...(on a parts car) ...but not anything that has been restored.
Re: What's your trick for removing wiper arms from the post [Re: GLR] #1010719
06/10/11 09:53 PM
06/10/11 09:53 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have some that look kinda like these . They work like pliers in reverse and have a rubber coating to keep the paint from getting damaged.
I think I bought them from NAPA, but it's been so long ago I'm not 100% sure.
Re: What's your trick for removing wiper arms from the post [Re: A12] #1010720
06/10/11 10:04 PM
06/10/11 10:04 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
when you put them back, dab the shafts with a touch of white grease. they'll pop right off next time...
Re: What's your trick for removing wiper arms from the post [Re: Neil] #1010721
06/10/11 10:07 PM
06/10/11 10:07 PM
Here
Here
Probably a good idea.
Re: What's your trick for removing wiper arms from the post [Re: Golden-Arm] #1010722
06/10/11 10:07 PM
06/10/11 10:07 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: What's your trick for removing wiper arms from the post [Re: A12] #1010723
06/10/11 10:10 PM
06/10/11 10:10 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
it's been awhile but isn't there a tab that needs to be released?
Re: What's your trick for removing wiper arms from the post [Re: mikemee1331] #1010724
06/10/11 10:15 PM
06/10/11 10:15 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
On some models,yes.
Re: What's your trick for removing wiper arms from the post [Re: GLR] #1010725
06/10/11 11:00 PM
06/10/11 11:00 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Re: What's your trick for removing wiper arms from the post [Re: NITROUSN] #1010726
06/11/11 06:57 AM
06/11/11 06:57 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Buying a tool you will use twice...maybe 4 times...kind of a waste. There is a dog leg latch on the underneath...I use a small screwdriver and push it out of the way otherwise it catches under the serrations of the splined section. I take a towel and put it over my wiper arm..nice and thick so I don't mar the metal. I grab a big pair of channel locks and grab on...swing back and forth 2 or 3 times and they are off...if its stubborn, squirt a little WD40 with the spray tip up under the splined area...reset the dog leg latch and do the other one..
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: What's your trick for removing wiper arms from the post [Re: Pyper70] #1010727
06/11/11 10:58 AM
06/11/11 10:58 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Bare hands... Seriously, grab the wiper arm & while pushing down toward the car on that, grab the part attached to the post & lift...
Re: What's your trick for removing wiper arms from the post [Re: Pyper70] #1010728
06/11/11 11:00 AM
06/11/11 11:00 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
BTW On the latch being described above, some have it, most don't... If it's there yeah, pry the latch out...
Re: What's your trick for removing wiper arms from the post [Re: A12] #1010729
06/11/11 12:14 PM
06/11/11 12:14 PM
Missouri
convertriple Offline
super gas
super gas
Missouri
I'm not sure about your X, but on my Dart, I use a small pick/hook to pull the lock tab away from the splines, then use a screwdriver to lift under the round part of the arm (around the splines).
Re: What's your trick for removing wiper arms from the post [Re: DirectSubjection] #1010730
06/16/11 12:52 AM
06/16/11 12:52 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
I was a wuss and finally just grabbed the biggest screwdriver (1/2" blade) I had and another screwdriver for a pivot/fulcrum. Pryed that little clip looking thing right out or there completely, laid a towel on the hood under the screwdriver handle I used for the fulcrum and pryed the wiper right at the wiper posts and off they came. They'll go back on with a little anti-seize (very little) and next ones I do I won't be such a wuss PRY THEM OFF WUSSES
Thanks for all of the help everyone
MikeR
Re: What's your trick for removing wiper arms from the post [Re: A12] #1010731
06/16/11 05:43 PM
06/16/11 05:43 PM
greenfield, ind.
P
PLMCRZY Offline
PLMCRZY  Offline
P
greenfield, ind.
some wipers have a small hole near the shaft that you can put a small nail in when you lift the wiper up off the w/s. this take the tension off the arm and makes it easier to remove. also some wipers have a latch that slides out when you lift wiper up off of w/s. does the same thing as the nail.
