no speedo or tach & abs light on #1010643
06/10/11 04:20 PM
06/10/11 04:20 PM
California
70SportSatellite Offline OP
super street
super street
California
My Dad called a couple of days ago and said the tach and speedo stopped working and the ABS light is on. Unfortunately he is a couple of states away or I would check it. It's a 1999 Jeep GCL with a 4.7. He said he checked the fuses and they were good. Has anyone had this happen and if so what did you find? Thanks
Re: no speedo or tach & abs light on [Re: 70SportSatellite] #1010644
06/10/11 05:36 PM
06/10/11 05:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A faulty ABS sensor on the rear end could kill the speedo and trigger an ABS light but the tach...?
Re: no speedo or tach & abs light on [Re: John_Kunkel] #1010645
06/10/11 07:05 PM
06/10/11 07:05 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
My Dakota did something like that. It was a broken ground inside the ECM. Have him check all the connectors at the ECM/ABS units to make sure they are not loose or corroded.
Re: no speedo or tach & abs light on [Re: slantzilla] #1010646
06/11/11 04:23 PM
06/11/11 04:23 PM
Sterling Heights, Michigan 483...
daniel_depetro Offline
This is a fairly common problem on the Rams. On those it's a speed sensor in the rear differential.
Is this your problem? I have no idea.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
