284/484 cam #1010590
06/10/11 02:52 PM
06/10/11 02:52 PM
pacific northwest
W
wings471 Offline OP
wings471  Offline OP
W
pacific northwest
I have a a 284/484 (DCC 4120235) camshaft I'm going to install in a 440 with approx. 10 to 1 compression. 3600 stall and 4.30 gears. torqueflite trans. What installed centerline would work the best for this motor please. Street car. Thanks for the input. (I hope I worded that correctly)
Re: 284/484 cam [Re: wings471] #1010591
06/10/11 02:55 PM
06/10/11 02:55 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think most guys like to advance them about 3-4*.
Coming soon!!!!
Re: 284/484 cam [Re: wings471] #1010592
06/10/11 03:14 PM
06/10/11 03:14 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
that cam is groung on 108 centers with 2 degrees advance ground into it. that would put the installed centerline at 106. i've done 104 without issue but for me 104 would be the limit. personal opinion here, 106 is probably ideal.
Re: 284/484 cam [Re: wings471] #1010593
06/10/11 04:48 PM
06/10/11 04:48 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would aim at 104!
Re: 284/484 cam [Re: wings471] #1010594
06/11/11 12:46 AM
06/11/11 12:46 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Are you aware that the vacuum is going to be low with that cam... If no power brakes, then you should be fine..
Just my $0.02...
Re: 284/484 cam [Re: Sinitro] #1010595
06/11/11 12:51 AM
06/11/11 12:51 AM
Dexter, Michigan
copper67440 Offline
mopar addict
copper67440  Offline
mopar addict
Dexter, Michigan
I've got the same cam in my 66,383 with 906 heads. It's been in this engine since the early 90's so I don't remember what it was put in at but I have no vacuum issues at all. Power brakes work fine.
