First run on the STREET! Oil pressure drops LOWat idle? #1010451
06/10/11 10:23 AM
06/10/11 10:23 AM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
I just got back from running the Challenger for the FIRST TIME . The oil PSI while running is b/w 45 - 55. At idle it drops to 15 - 20 . Is this NORMAL??? In the garage it ran at idle b/w 40 - 50 but it's never been driven.
It's is a FRESH stock built 440 with a 268* Comp cam with 0 miles. A crusier built car - no mods....Running 10W-30.
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: Plum440] #1010452
06/10/11 10:28 AM
06/10/11 10:28 AM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
IS the rule of thumb 10 per 1,000 in relation to RPMs? Just found that on an on-line search
A couple of Jeeps…
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: Plum440] #1010453
06/10/11 10:32 AM
06/10/11 10:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes it is , though that is a little low for a fresh build , what pump do you have ?
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: Plum440] #1010454
06/10/11 10:33 AM
06/10/11 10:33 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Should be OK, keep an eye on it and if it don't go down anymore, it'll be fine. Good luck with it and enjoy!
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: Plum440] #1010455
06/10/11 10:33 AM
06/10/11 10:33 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
YES, you are looking for 10PSI/1K RPM typically....I think you are fine with 15-20 at idle...some setups might show more, etc....but this should be fine.
Can you tell regarding your engine what the bearing clearances were like? Loose or tight side?
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: Diplomat360] #1010456
06/10/11 10:39 AM
06/10/11 10:39 AM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
Not sure about the bearing clearances. I do know the builder and the shop have a GREAT reputation! Thank!
A couple of Jeeps…
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: JohnRR] #1010457
06/10/11 10:40 AM
06/10/11 10:40 AM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
Melling high performance - OEM type.
A couple of Jeeps…
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: Diplomat360] #1010458
06/10/11 10:41 AM
06/10/11 10:41 AM
scratchnfotraction Offline
gauges can vary also
i have one thats 10lbs off from any others i have used.
my 440 does about the same thing and its well used with 75,000 miles on it.
may bump up to a thicker oil when you change it.
i run the napa fleet 15/40 in all of mine,10/30 drops pressure way down on mine
you did break the cam in with a oil additive with high zink correct?
on a fresh engine I change the oil 2-3 times in short order and cut the filter open to look for junk/shavings..ect
after that i lets it rip and change it when it gets black
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: Challenger 1] #1010459
06/10/11 10:42 AM
06/10/11 10:42 AM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
Thanks! I'm sure you remember that first time feeling of rowing through the gears of your FIRST BIG BLOCK!
A couple of Jeeps…
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: Plum440] #1010460
06/10/11 10:45 AM
06/10/11 10:45 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd like a little more than that but that is thin oil. Should be ok but I wouldn't want it to go too much lower.
Coming soon!!!!
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: Mr.Yuck] #1010461
06/10/11 11:38 AM
06/10/11 11:38 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
my big block used full groove main bearings (full time oiling vs half with stock bearings) and an High Volume oil pump, and it had the following numbers:
with 15w40 oil:
PSI at cold engine start up 75 psi
hot idle 30 psi
hot cruise 45-50 psi below 2000 rpm, and 60-65 above 2000 rpm.
switched to 10w30:
cold start up 75 psi
hot idle 20-25
hot cruise below 2000 rpm was 40 or so, and 55-ish above 2000 rpm.
knowing if you have full groove main bearings or not would help, as well as whether or not it's a stock pump or HV pump. (you said "high performance OEM type)
**Photobucket sucks**
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: Plum440] #1010462
06/10/11 01:39 PM
06/10/11 01:39 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
What RPM is it idling at? Like mentioned above, the pressures you gave are close to the minimums. I would run a bit thicker oil....15-40 or something.
I just bolted on the billet Milidon pump and their low-profile, baffled roadrace pan. I'm sure my hot idle pressures will be up now.
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: jbc426] #1010463
06/10/11 01:44 PM
06/10/11 01:44 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
what kind of 10w/30? high zinc "racing" ? or just regular oil?
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: ademon] #1010464
06/10/11 03:15 PM
06/10/11 03:15 PM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
I'm just running Pennzoil 10W-30 with a break-in additive for the cam.
The oil pump is a high volume oil pump.
I think I'll switch to a thicker oil after I drain this first round.
Thanks!!
A couple of Jeeps…
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: JohnRR] #1010465
06/10/11 08:16 PM
06/10/11 08:16 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
. Its not too low, but is low for a new motor and it would be nice to know why.
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: BSB67] #1010466
06/10/11 09:08 PM
06/10/11 09:08 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
That's why I asked about full vs half groove main bearings.
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: 70Cuda383] #1010467
06/10/11 11:01 PM
06/10/11 11:01 PM
IN
ahy Offline
ahy  Offline
IN
With performance bearing clearance on the rods and mains - around .0025" vs OE at about .0015 - and/or full groove main bearings your oil pressure would be typical. I'd bump up to 15W40 diesel engine oil and call it good. 15 psi shouldn't hurt the engine but I'd be happier with 20 at hot idle.
With OE bearings/clearances, I'd call that a bit low. Suggest you get the info from your shop as mentioned above on bearing setup.
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: Plum440] #1010468
06/10/11 11:17 PM
06/10/11 11:17 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would go to a 15/40 min maybe a 20/50 oil
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: Dodgem] #1010469
06/10/11 11:46 PM
06/10/11 11:46 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
And if that doesn't work it is so easy to shim the relief spring on the big block pump. The relief spring plug faces the back of the engine on the pump.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: Dads426] #1010470
06/11/11 12:52 AM
06/11/11 12:52 AM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
Thats not excessively low as long as it comes up as you rev engine. Mopars are famous for low idle oil pressure. Just keep an eye on it as mentioned above. If it is a constant concern to you switch to a heavier weight or go to an adjustable pressure set up on your oil pump. I've ran Mopars with your pressure readings for many many years with no problems.
Maynard
