Re: AAAAHHH!! Frustrated and need help!
[Re: Yesdogjr]
#1009991
06/09/11 02:32 PM
06/09/11 02:32 PM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
2. The motor is a 1969 340 and has the timing marks cast into the cover on the passenger side behind the watter pump inlet, so you cant see them. To add to the problem the balancer is an aftermarket piece and so the timing marks are 90deg off. I cannot seem to get this timing right. Comp said that the initial timing is 12-14 deg total timing is 36-38 and they want it all in before 3000. So according to MSD they said to use the silver bushing (25 Deg) and by their timing graph (E) I should use one light silver spring and one light blue spring and this is what I have done. Since I cannot use the timing light and do it the correct way im trying to get it close by ear. I can get it sounding right in the shop but when I test drive it the timing sounds way off when the motor is under a load.
What should I do???
Replace the timing cover with the CORRECT later model part . or get the engine to TDC and create timing marks where they can be seen if you don't want to do what you should have done initially .
[Re: mikemee1331]
#1009992
06/09/11 02:47 PM
06/09/11 02:47 PM
Posts: 2,177 ill
dennismopar73
ill
msd is supposed to be hook direct to batt on both pos and neg , the kon/off can be wired to a keyed fuse box terminal by no means would it be wired to the coil jmo
[Re: JohnRR]
#1009993
06/09/11 02:50 PM
06/09/11 02:50 PM
Posts: 15,487 Florida
scratchnfotraction
What should I do???
or get the correct wp/damper/rad to go with the t-cover you have.
use a vac gauge on the full vac port of the carb,advance timeing till you get your highest vac reading,adjust idle air screws to get highest vac reading playing with it till you get the highest vac reading
then back it off one full # and lock the dist down (example..if highest is 19..back it down to 18)
this will get you real close and in the ball park for timeing with out a time light
then get a light on it and make note of where its at for future referance.
you can now use that as a base line,then test drive and adjust more if needed with a light and the vac gauge together to fine turn timeing and the carb setting.
my
[Re: dennismopar73]
#1009995
06/09/11 02:51 PM
06/09/11 02:51 PM
Posts: 1,107 Spring Valley ,Ca.
moparsquid
Spring Valley ,Ca.
[Re: Andrewh]
#1009997
06/09/11 03:23 PM
06/09/11 03:23 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
Your brake issue might be the same thing that my friend did on his Dart. He had the calipers switched from left to right. If the bleeder screw is not at the highest point,pointing up,they will not bleed properly. He had the bleeders pointing down. After switching the calipers from left to right,they bleed out fine,problem solved. Maybe you solution will be the same.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
