I NEED A NEW CLUTCH #1009703
06/08/11 11:15 PM
06/08/11 11:15 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
I put a warmed up 383 in my 70 Road Runner.
Putting out about 400 HP @ the flywheel. I replaced the flywheel with a new Billet steel unit. The clutch disc and pressure plate were installed new back in 2006, 10.95 dia. stock... I reused this clutch set up but now I am getting slippage during gear changes. I am looking for a good pressure plate and disc (10.95) that will handle the upgrade without breaking the bank. Ram makes a muscle car kit,30% more clamping power over stock, and a power grip, 80% over stock... Any advice on what will work best.
F.A.S.T/1969 SUPER BEE/383/AUTO/AVS 11.58 @ 117.98 1.71 60ft mph F.A.S.T Legal
1969 DART SWINGER/340(420CI)/6.52 @ 105.39 1.45 60ft (1/8 mile)10.22 @130.5 (1/4 mile)
Harry
Re: I NEED A NEW CLUTCH [Re: chagjr] #1009704
06/08/11 11:24 PM
06/08/11 11:24 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Talk to Jamie @ Passon.
I would suggest a McCleod B&B and kevlar disc...
http://www.passonperformance.com/
Just my $0.02..
Re: I NEED A NEW CLUTCH [Re: chagjr] #1009705
06/08/11 11:27 PM
06/08/11 11:27 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Centerforce dual friction
Re: I NEED A NEW CLUTCH [Re: Dcuda69] #1009706
06/09/11 02:46 AM
06/09/11 02:46 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I would probably go Centerforce Dual Friction. I would absolutely stay away from Zoom stuff.
Re: I NEED A NEW CLUTCH [Re: Ramrod39] #1009707
06/09/11 08:17 AM
06/09/11 08:17 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree the CF.Have one in my 600hp 440 and its street strip.Been in 10 years and still great.rocky
Chrysler Firepower
Re: I NEED A NEW CLUTCH [Re: Ramrod39] #1009708
06/09/11 09:16 AM
06/09/11 09:16 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Why?
No complaints here.
Re: I NEED A NEW CLUTCH [Re: Commando1] #1009709
06/09/11 10:24 AM
06/09/11 10:24 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
McLeod makes a good clutch. Assuming your trans is 23 spline:
http://www.brewersperformance.com/proddetail.asp?prod=MC1023
http://www.brewersperformance.com/proddetail.asp?prod=MCP1023
Either one of these are available with a diaphragm style pressure plate (Like Centerforce)
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
Re: I NEED A NEW CLUTCH [Re: 64dodge572] #1009710
06/09/11 12:49 PM
06/09/11 12:49 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
I have the exact McLeod ceramic borg & beck setup above and even bought it through Brewers. Fantastic setup for my 425ish HP 440. great price also.
very clever dinner. appetizing food fit neatly into interesting round pie.
Re: I NEED A NEW CLUTCH [Re: HitIt] #1009711
06/09/11 01:11 PM
06/09/11 01:11 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I use the same organic/ceramic Mcleod disc and their 360951 Borg&Beck/long pressure plate. If I need to step it up I can either get the more aggressive disc with ceramic on both sides or add counterweight to the pressure plate fingers. or both.
Re: I NEED A NEW CLUTCH [Re: 64dodge572] #1009712
06/09/11 03:32 PM
06/09/11 03:32 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Last Zoom I had lasted maybe a year.It came out in pieces.Replace it with a McCleod and had no problems except it was stiff.Went CF and its the vest Ive run.Rocky
Chrysler Firepower
Re: I NEED A NEW CLUTCH [Re: 64dodge572] #1009713
06/09/11 04:14 PM
06/09/11 04:14 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Dan
If your looking for the light pedal feel here are the same pkgs with the diaphragm pressure plates. McLeods advantage in the 23 spline version is the 10.875" disc over the Centerforce true 10.5".
http://www.brewersperformance.com/proddetail.asp?prod=MCD1023
http://www.brewersperformance.com/proddetail.asp?prod=MCDP1023
Dan
FAX 937-947-4419
Re: I NEED A NEW CLUTCH [Re: 64dodge572] #1009714
06/10/11 12:37 AM
06/10/11 12:37 AM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
Dan
Just ordered. Thanks!
Harry
Re: I NEED A NEW CLUTCH [Re: Commando1] #1009715
06/10/11 02:22 AM
06/10/11 02:22 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Why?
No complaints here.
I had two different Zoom set ups fail on two different cars. Neither one had more than 1000 miles on them. One was at the track with slicks, the other was a street crusier. When the Zoom friction material falls off the disk you can read the "Made in Thailand" stamp on the plate.
Replaced the failed Zoom units, one with a Weber and one with a Centerforce. No problems with the non-Zoom stuff. Love the feel of the Centerforce....
