Dana 60 spline count? #1009599
06/08/11 09:18 PM
06/08/11 09:18 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
I have an 82+/- Ford truck Dana that is going to be cut down and built for a 68 A12 spec Road Runner. I believe it has 35 spline axles and I have been told I should change the side gears to 30 spline. Not a big deal since I will buy axles and go through the unit, but my question is why?
Careful, your character's showing!
Re: Dana 60 spline count? [Re: mopar346] #1009600
06/08/11 10:19 PM
06/08/11 10:19 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
If it has a good power-lock or track-lock I would use whatever spline the side gears are.If they are 35 spline don't change it to thirty spline unless you need it for the sure-grip you are planning to use.
Doctordiff can set you up with a good set of axles and a good sure-grip
Gus
64 Plymouth Savoy
Dana 60
Re: Dana 60 spline count? [Re: fourgearsavoy] #1009601
06/08/11 10:37 PM
06/08/11 10:37 PM
mopar346 Offline OP
mopar346  Offline OP
Thanks, it has a locker of some sort not sure which, it is a clutch style if I remember correctly. I already have the parts list from Dr. Diff for axles and housing ends. I wasn't sure if strength was an issue, but frankly it will probably never be heavily tested. Maybe 6-700 hp at most, but not enough chassis to put it down or hook seriously.
Re: Dana 60 spline count? [Re: mopar346] #1009602
06/09/11 12:17 AM
06/09/11 12:17 AM
Rittman Ohio
Rittman Ohio
I have 35 spline Moser axles and spool in my Savoy with around 600 HP but I race it with slicks and a manual transmission I would think 30 spline axles would hold up in a car with limited traction though.
Gus
64 Plymouth Savoy
Dana 60
Re: Dana 60 spline count? [Re: mopar346] #1009603
06/09/11 03:36 PM
06/09/11 03:36 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Since you are building from scratch you should use 35 spline stuff since it cost little or no more for axles and 35 spline side gears are relatively cheap for a trac lok or power lok if your's doesn't have them. It's good insurance in case you decide to put some drag slicks on it.
Re: Dana 60 spline count? [Re: 446acuda] #1009604
06/09/11 07:39 PM
06/09/11 07:39 PM
mopar346 Offline OP
mopar346  Offline OP
Oh I'm reasonably sure it will have slicks on it at some time. So are ya'll saying the 35s are actually stronger than 30s? My comment about traction is from the fact that I do not plan to build the chassis to hook, ie roll bar or tied subframes. Without the proper chassis it wont transfer well enough to hook hard enough to hold the hp on tires, even slicks, that will fit in stock wheel wells.
Re: Dana 60 spline count? [Re: mopar346] #1009605
06/09/11 07:48 PM
06/09/11 07:48 PM
scratchnfotraction Offline
i thought you kept the 30 spline side gears for useing 8 3/4 axle in the D-60
other wize swap to 35 spline
Re: Dana 60 spline count? [Re: scratchnfotraction] #1009606
06/09/11 09:26 PM
06/09/11 09:26 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
small hi jack
I called Randys Ring and Pinion today..
I asked the parts guy about this 30/35 spline D 60 subject...
He told me that DANA/SPICER never made a D60 35 spline rearend for any aplication.
They did make D 60 35 spline 4x4 "FRONT" axles
So for you guys hunting the junkyards for a 35 spline D 60 "REAR" axle, it doesnt exhist..
D 70s do have 35 spline axles...
I am truckless..
Re: Dana 60 spline count? [Re: 340SHORTY] #1009607
06/09/11 10:06 PM
06/09/11 10:06 PM
mopar346 Offline OP
mopar346  Offline OP
Well I am absolutely sure they know more than me, but I am almost certain that they one I have is 35 spline and I know it's a 60. I pulled one of the axles and counted the splines, maybe I have it backwards but I would bet money I counted 35.
Re: Dana 60 spline count? [Re: mopar346] #1009608
06/09/11 10:23 PM
06/09/11 10:23 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
I know for a fact 70 DANA 60's did have 35 spline axles... Had one in my 70 Roadrunner!
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Dana 60 spline count? [Re: MoparJunkie] #1009609
06/09/11 11:29 PM
06/09/11 11:29 PM
BDW Offline
BDW  Offline
Dana in our Mopars used 35 & 23 splined axles.
http://www.moparts.org/Tech/Archive/axle/img/Rear_Axles_14.jpg
Re: Dana 60 spline count? [Re: BDW] #1009610
06/10/11 01:21 AM
06/10/11 01:21 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I wish Dr Diff would clear the fog ....
I am truckless..
Re: Dana 60 spline count? [Re: 340SHORTY] #1009611
06/10/11 01:53 AM
06/10/11 01:53 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I have a dana 70 4.56 and up trac lock if you want to do the Jana 76 conversion. It uses the 10.5" ring gear in the 60 housing. Worth the extra 150.00 for the special bearings to install it. Never have to worry about breaking a ring gear. You might also look at using the Jeep ends, if you want a factory rear disc brake for less than $100.00. The Ford Explorer uses the same rear brakes as a Jeep Grand Cherokee but with the ford metric bolt pattern. The jeep uses a Timken set 10 which has a 1.562" ID and the 35 spline gears are 1.5" O.D. Just some food for thought. Tim
Re: Dana 60 spline count? [Re: 340SHORTY] #1009612
06/10/11 03:53 AM
06/10/11 03:53 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
'70 and newer Mopar passenger car Dana 60 rearends came with 35 spline axles.
Jeep pickup Dana 60 rears, as well as some Ford C-clip Dana 60 rears also came with 35 spline internals.
Re: Dana 60 spline count? [Re: DoctorDiff] #1009613
06/10/11 10:10 AM
06/10/11 10:10 AM
mopar346 Offline OP
mopar346  Offline OP
So general consensus is stay with whatever is in it for my application since it wont really be tested. But if for some reason (wear) I have to change them go with the 30s. Right?
Re: Dana 60 spline count? [Re: 340SHORTY] #1009614
06/10/11 10:34 AM
06/10/11 10:34 AM
its an 82+ FERD D-60 not a mopar D-60
that is the confusion
