Dana 60 spline count?
#1009599
06/08/11 09:18 PM
06/08/11 09:18 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I have an 82+/- Ford truck Dana that is going to be cut down and built for a 68 A12 spec Road Runner. I believe it has 35 spline axles and I have been told I should change the side gears to 30 spline. Not a big deal since I will buy axles and go through the unit, but my question is why?
Careful, your character's showing!
Re: Dana 60 spline count?
[Re: fourgearsavoy]
#1009601
06/08/11 10:37 PM
06/08/11 10:37 PM
mopar346
Thanks, it has a locker of some sort not sure which, it is a clutch style if I remember correctly. I already have the parts list from Dr. Diff for axles and housing ends. I wasn't sure if strength was an issue, but frankly it will probably never be heavily tested. Maybe 6-700 hp at most, but not enough chassis to put it down or hook seriously.
[Re: mopar346]
#1009602
06/09/11 12:17 AM
06/09/11 12:17 AM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have 35 spline Moser axles and spool in my Savoy with around 600 HP but I race it with slicks and a manual transmission I would think 30 spline axles would hold up in a car with limited traction though. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: mopar346]
#1009603
06/09/11 03:36 PM
06/09/11 03:36 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
Since you are building from scratch you should use 35 spline stuff since it cost little or no more for axles and 35 spline side gears are relatively cheap for a trac lok or power lok if your's doesn't have them. It's good insurance in case you decide to put some drag slicks on it.
[Re: scratchnfotraction]
#1009606
06/09/11 09:26 PM
06/09/11 09:26 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
small hi jack I called Randys Ring and Pinion today.. I asked the parts guy about this 30/35 spline D 60 subject... He told me that DANA/SPICER never made a D60 35 spline rearend for any aplication. They did make D 60 35 spline 4x4 "FRONT" axles So for you guys hunting the junkyards for a 35 spline D 60 "REAR" axle, it doesnt exhist.. D 70s do have 35 spline axles...
I am truckless..
[Re: DoctorDiff]
#1009613
06/10/11 10:10 AM
06/10/11 10:10 AM
mopar346
So general consensus is stay with whatever is in it for my application since it wont really be tested. But if for some reason (wear) I have to change them go with the 30s. Right?
