estimate my hp #1009550
06/08/11 07:57 PM
06/08/11 07:57 PM
Indiana
O
Osyman Offline OP
Osyman  Offline OP
O
Indiana
67 440 block .030 over
915 heads uncut
stock crank
eagle h beam rods
wiseco 10.1:1 forged pistons
edelbrock single plane
street avenger 770
mp 284/484 cam
Re: estimate my hp [Re: Osyman] #1009551
06/12/11 03:21 PM
06/12/11 03:21 PM
Redding,CA USA
440charger500 Offline
Redding,CA USA
I'm gonna say 400hp
Re: estimate my hp [Re: 440charger500] #1009552
06/12/11 03:31 PM
06/12/11 03:31 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I'll say more like 420-430 FWHP with tuning. With that compression, i would have went with the .509, I had a 446 like yours & I dropped .5 & gained 5 mph from the .484 too the .509 at 3700 ft. alt. in a 72 duster & that was straight up not even degreed, & too boot the tranny was heading south on that pass, that was the only pass i made. A combo like that likes around 510-530 lift & dur. @50 in the low-mid 240s, the .509s dur. @50 if i'm not misten is .248/.252., I'd install it at 104*.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: estimate my hp [Re: joedust451] #1009553
06/12/11 07:38 PM
06/12/11 07:38 PM
dogdays Offline
dogdays  Offline
376 brake horsepower corrected. Calculated by my guess-top dyno. The stock heads are your weak point. There's 50 hp or more to be had in the heads with everything else the same.
R.
Re: estimate my hp [Re: dogdays] #1009554
06/12/11 08:32 PM
06/12/11 08:32 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
This is what mine calculated useing "BONE" stock 906s with casting flash & an 530/540 solid cam, 250/256 @50, 9.73 compression, 1.7/8 headers, Weiand TR & 600 holleys. Calculated 10.87 @ 123.58 @ 3200 lbs., that was on a very bad 1.62 60ft. 4400 stall, 4.10 gears.
By ET- 443.19 RWHP, 492.44 FWHP
By MPH- 435.28 RWHP, 483.65 FWHP
Stock iron heads can still run great.
http://www.wallaceracing.com/hpcalculatorquarter.php
Re: estimate my hp [Re: joedust451] #1009555
06/12/11 09:59 PM
06/12/11 09:59 PM
Indiana
O
Osyman Offline OP
Osyman  Offline OP
O
Indiana
thanks. im not looking for max hp, just want to leave heads alone in case i go alum heads and wanna sell the 915's. i might put the 509 cam in,how would vacuum be at idle?
Re: estimate my hp [Re: Osyman] #1009556
06/13/11 01:00 AM
06/13/11 01:00 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
About 7 give or take in N, Just make sure you have a good adj. ignition, & degree it if possible, i've run them straight up with a good chain set & they ran very strong.
Re: estimate my hp [Re: joedust451] #1009557
06/13/11 03:18 AM
06/13/11 03:18 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
In good tune my guess would be about 425 hp. I ran the .484-284 cam in a 383 Dart and that .484 worked real nice. It was a stock 383 with 452 heads cut for 9.5 comp and some bowl blend porting done. I put the .484 cam on a 104 centerline and used stock rockers. In my sons Dart that weighs 3550 with him in it it ran 12.30's @ 110 using 3.91 gears and the Eddy RPM intake with a 750 DP. Just saying that the .484 worked real nice in that 383 and had a nice little muscle car rump rump in the idle which I liked. Good luck , Ron
Re: estimate my hp [Re: 383man] #1009558
06/13/11 01:31 PM
06/13/11 01:31 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Yeah in the 383 the .484 would work nice, but in a 440 the .509 will kick its ass, BTDT
