Re: Slow Shifting 727????????
[Re: okie]
#1009034
06/08/11 03:53 PM
06/08/11 03:53 PM
Posts: 15,487 Florida
scratchnfotraction
Ok what is the TP linkage? Ronnie
throttle pressure valve linkage,Rods or Rod going from carb down to lever on the trans.
[Re: John_Kunkel]
#1009039
06/09/11 06:55 PM
06/09/11 06:55 PM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
With the throttle at wot the pressure linkage on the trans should be all the way back, without excessive pressure.
Since it's shifting late the linkage appears to already be too far back.
Is the carb stock or aftermarket?
So have I been misled to believe that is the correct adjustment. That's how I have mine and it shifts fine.
Please don't think I'm disputing what your saying, you are certainly more knowledgeable about this than I am.
Hmmmmmmm maybe I can learn sumpin here too.
If it's not correct please explain. I just read my FSM and that's what it says.
[Re: Mopar_Country]
#1009040
06/09/11 07:01 PM
06/09/11 07:01 PM
scratchnfotraction
I all ways push the TV lever forward against the stop and the linkage against the throttle stud.
then move it back a little at a time to get the shift points where I want them.
the TV lever does not have to be ALL the way back against the stop at WOT.
If I understand it correctly.
maybe John will clear it up for us?
Re: Slow Shifting 727???????? Up date
[Re: okie]
#1009044
06/12/11 06:41 PM
06/12/11 06:41 PM
Posts: 25,928 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Shortening the linkage will make it shift sooner at any given throttle setting.
