Slow Shifting 727???????? #1009031
06/08/11 08:53 AM
06/08/11 08:53 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
On my RoadRunner the tranny seems to take a long time to shift, it really winds up before it will. Can I adjust the kick down rod to make it shift faster? Any advice will help. Thanks Ronnie
Re: Slow Shifting 727???????? [Re: okie] #1009032
06/08/11 11:33 AM
06/08/11 11:33 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Adjust the TP linkage
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Slow Shifting 727???????? [Re: 69L78Nova] #1009033
06/08/11 12:50 PM
06/08/11 12:50 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Ok what is the TP linkage? Ronnie
Re: Slow Shifting 727???????? [Re: okie] #1009034
06/08/11 03:53 PM
06/08/11 03:53 PM
scratchnfotraction Offline
throttle pressure valve linkage,Rods or Rod going from carb down to lever on the trans.
Re: Slow Shifting 727???????? [Re: scratchnfotraction] #1009035
06/08/11 06:08 PM
06/08/11 06:08 PM
Under My Car
Mopar_Country Offline
Under My Car
With the throttle at wot the pressure linkage on the trans should be all the way back, without excessive pressure.
Re: Slow Shifting 727???????? [Re: Mopar_Country] #1009036
06/08/11 07:18 PM
06/08/11 07:18 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
OK, Thanks I'll try that and see if that fixes it. Ronnie
Re: Slow Shifting 727???????? [Re: okie] #1009037
06/08/11 08:14 PM
06/08/11 08:14 PM
Under My Car
Under My Car
I wouldn't drive it until it's right. Trans damage will follow.
Re: Slow Shifting 727???????? [Re: Mopar_Country] #1009038
06/09/11 05:04 PM
06/09/11 05:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Since it's shifting late the linkage appears to already be too far back.
Is the carb stock or aftermarket?
Re: Slow Shifting 727???????? [Re: John_Kunkel] #1009039
06/09/11 06:55 PM
06/09/11 06:55 PM
Under My Car
Under My Car
So have I been misled to believe that is the correct adjustment. That's how I have mine and it shifts fine.
Please don't think I'm disputing what your saying, you are certainly more knowledgeable about this than I am.
Hmmmmmmm maybe I can learn sumpin here too.
If it's not correct please explain. I just read my FSM and that's what it says.
Re: Slow Shifting 727???????? [Re: Mopar_Country] #1009040
06/09/11 07:01 PM
06/09/11 07:01 PM
I all ways push the TV lever forward against the stop and the linkage against the throttle stud.
then move it back a little at a time to get the shift points where I want them.
the TV lever does not have to be ALL the way back against the stop at WOT.
If I understand it correctly.
maybe John will clear it up for us?
Re: Slow Shifting 727???????? [Re: scratchnfotraction] #1009041
06/09/11 07:17 PM
06/09/11 07:17 PM
Under My Car
Under My Car
I hope so cause I'm thoroughly confused now.
Re: Slow Shifting 727???????? [Re: Mopar_Country] #1009042
06/09/11 08:00 PM
06/09/11 08:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Adjusting the TP linkage so that it's full back at WOT usually results in late light throttle upshifts (the OP's problem). Some folks do it and like the late shifts, others don't.
The factory adjustment procedure is shown below but this is only with factory carb and linkage. If an aftermarket carb is used without the correct Mopar throttle lever adapter it'll never work correctly.
Re: Slow Shifting 727???????? Up date [Re: John_Kunkel] #1009043
06/12/11 09:58 AM
06/12/11 09:58 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Ok, I adjusted the linkage out some and it seems to shift better to second but it really made no difference on third gear. So I guess now I will try adjusting in in shorter some and try that. Ronnie
Re: Slow Shifting 727???????? Up date [Re: okie] #1009044
06/12/11 06:41 PM
06/12/11 06:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Shortening the linkage will make it shift sooner at any given throttle setting.
