suede finish question #1008539
06/07/11 10:23 AM
06/07/11 10:23 AM
SE Pa.
LimeliteAero Offline OP
SE Pa.
Does anyone know if the suede finish on the interior parts has any sheen to it or is it flat?
TIA........
Re: suede finish question [Re: LimeliteAero] #1008540
06/07/11 01:27 PM
06/07/11 01:27 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
It's flat.
Actually comes out like an enamel that was sprayed too dry. It has a rough texture, kind of like an interior version of organisol.
Re: suede finish question [Re: RP's R/T's] #1008541
06/08/11 10:00 AM
06/08/11 10:00 AM
SE Pa.
SE Pa.
Thanks I know about the texture but am unsure about any gloss to the finish?
Re: suede finish question [Re: LimeliteAero] #1008542
06/08/11 10:42 AM
06/08/11 10:42 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I don't know that I would call it completely flat in sheen.
I've done a few, in different colors and they all have a VERY small amout on sheen to them. not enough I would call them satin or gloss by any means though.
I'll see if I can find a picture of one I did recently
edit,
no pics on this PC,
I have a 1970 B-body column on the bench now in baltic blue. I'll snap a picture later today to show it.
Re: suede finish question [Re: gtx6970] #1008543
06/08/11 10:43 AM
06/08/11 10:43 AM
SE Pa.
SE Pa.
Thanks Bill....
heading to bed so Ill check it out later.
Re: suede finish question [Re: LimeliteAero] #1008544
06/08/11 04:01 PM
06/08/11 04:01 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Here's my 70 column in baltic blue
Re: suede finish question [Re: 70runner] #1008545
06/10/11 09:41 AM
06/10/11 09:41 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
This is probably the best view to see the color and shine ,,, or lack there of.
these are all the same column taken under various lighting conditions.
indoors - shop lighting - no flash
Re: suede finish question [Re: gtx6970] #1008546
06/10/11 09:42 AM
06/10/11 09:42 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
same conditions. EXCEPT with a flash on.
Re: suede finish question [Re: gtx6970] #1008547
06/10/11 09:43 AM
06/10/11 09:43 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
outdoors, partly cloudy day, no flash
and if you click on the attachment it opens the picture up much larger.
Re: suede finish question [Re: gtx6970] #1008548
06/10/11 04:40 PM
06/10/11 04:40 PM
SE Pa.
SE Pa.
Bill,
Thanks so much for taking the time to do this for me. the last picture tells me a lot......
Re: suede finish question [Re: LimeliteAero] #1008549
06/10/11 11:12 PM
06/10/11 11:12 PM
BC
70RT27N Offline
70RT27N  Offline
BC
For those that have used this paint, I believe I read that it is thinned on a 1:1 ratio with lacquer thinner, and that it can be sprayed over bare metal.
Is this correct? Would I better off using an etch primer first?
Thanks.
Re: suede finish question [Re: 70RT27N] #1008550
06/11/11 09:54 AM
06/11/11 09:54 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Thanks.
I spray it 2 to 1 , and have always use an etching primer under it. haven't had a problem yet
Re: suede finish question [Re: gtx6970] #1008551
06/11/11 10:26 AM
06/11/11 10:26 AM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
What brand of this paint do you recommend?
Re: suede finish question [Re: gtx6970] #1008552
06/11/11 01:15 PM
06/11/11 01:15 PM
BC
70RT27N Offline
70RT27N  Offline
BC
Thanks.
Thank you!
Re: suede finish question [Re: rayztoy] #1008553
06/12/11 09:06 PM
06/12/11 09:06 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Anyone...
Re: suede finish question [Re: rayztoy] #1008554
06/12/11 10:39 PM
06/12/11 10:39 PM
BC
70RT27N Offline
70RT27N  Offline
BC
Anyone...
I received mine from Mike Mancini...
https://board.moparts.org/ubbthreads/show...e=0#Post5373970
