Re: suede finish question
[Re: LimeliteAero]
#1008542
06/08/11 10:42 AM
06/08/11 10:42 AM
Posts: 21,406 It's a dry heat
gtx6970
It's a dry heat
I don't know that I would call it completely flat in sheen.
I've done a few, in different colors and they all have a VERY small amout on sheen to them. not enough I would call them satin or gloss by any means though.
I'll see if I can find a picture of one I did recently
edit, no pics on this PC, I have a 1970 B-body column on the bench now in baltic blue. I'll snap a picture later today to show it.
[Re: 70RT27N]
#1008550
06/11/11 09:54 AM
06/11/11 09:54 AM
gtx6970
It's a dry heat
For those that have used this paint, I believe I read that it is thinned on a 1:1 ratio with lacquer thinner, and that it can be sprayed over bare metal.
Is this correct? Would I better off using an etch primer first?
Thanks.
I spray it 2 to 1 , and have always use an etching primer under it. haven't had a problem yet
[Re: gtx6970]
#1008552
06/11/11 01:15 PM
06/11/11 01:15 PM
Posts: 396 BC
70RT27N
BC
Thanks.
Thank you!
[Re: rayztoy]
#1008553
06/12/11 09:06 PM
06/12/11 09:06 PM
Posts: 1,169 Richmond, VA
rayztoy
Richmond, VA
What brand of this paint do you recommend?
Anyone...
