2000 durango A/C not workie help #1008105
06/06/11 09:01 PM
06/06/11 09:01 PM
Henderson Kentucky
0791challenger Offline OP
Henderson Kentucky
Compressor runs all the time, shows 45 lbs on the gauge. I let pressure out down to 25 or so, compressor never kicked off and when I went to put some juice in it it went form 25ish to 45 in like 2 seconds. And still not cooling anybody have any ideas?
Josh
Re: 2000 durango A/C not workie help [Re: 0791challenger] #1008106
06/06/11 10:32 PM
06/06/11 10:32 PM
IN
ahy Offline
ahy  Offline
IN
Is the line coming out of the evaporator in the pass compartment cool? If it is you might have a broken/stuck air door or actuator in the heater box with no air flow over the evaporator. Another possibility is the temp sensor in the evaporator core isn't cycling the compressor and the core is iced up. If this is the case the AC would work for a while after start up and then sort of fade out with the compressor running all the time. Both of these could be combined to make your problem.
If the return line from the evaporator is warm, I don't know what's going on.
Re: 2000 durango A/C not workie help [Re: ahy] #1008107
06/06/11 10:52 PM
06/06/11 10:52 PM
Henderson Kentucky
Henderson Kentucky
Nope return line does not get cool.
Re: 2000 durango A/C not workie help [Re: 0791challenger] #1008108
06/07/11 01:18 AM
06/07/11 01:18 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
So what's the HIGH side reading?
The low side's only half the picture.
It could as simple [yet expensive] as the compressor gone away. Or a litany of other possibilities.
Down to just a blue car now.
Re: 2000 durango A/C not workie help [Re: 68HemiB] #1008109
06/07/11 06:41 PM
06/07/11 06:41 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Had the same issue on my Dakota. The orifice tube was plugged.
Re: 2000 durango A/C not workie help [Re: slantzilla] #1008110
07/20/11 06:18 PM
07/20/11 06:18 PM
Henderson Kentucky
Henderson Kentucky
Ok time to revisit the A/C subject.
The high and low side read 10lbs no matter if the A/C is off or on. Compressor I am assuming?
Josh
