SRD Assassin Traction Device. is anybody useing them?? #1007772
06/06/11 11:22 AM
06/06/11 11:22 AM
Central Missouri Fort Leonard...
mopar65 Offline OP
mopar65  Offline OP
I was checking site out over the weekend and found this site.
http://srdparts.com/index.php?option=com...50&Itemid=1
i emailed them and they said they would work fine with my mopar superstock springs and i know caltracs says not to use theres with super stock springs.so before i go and spend the money i thought i would see if anybody is running a set before i spend the money on them. but they look like a nice set up thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: SRD Assassin Traction Device. is anybody useing them?? [Re: mopar65] #1007773
06/06/11 12:13 PM
06/06/11 12:13 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Hey bobby, I thought you had Caltracs, Those look like there plenty adjustable, but will they work with "multi" leaf springs, if not, then you might as well get the Caltracs & mono leaf kit, you'll still need an adj. shock, those also look like there more of a traction bar type set up, The caltracs have that rap-around type set-up that puts pressure on the top of the spring close too the eye, this keeps the spring from buckling at that point, thats the weak area, with those your showing it would need a strong (thick) front section buy the eye so it won't flex up, of coarse if you look at the caltrac monos there very thick up front, over a 1/2", maybe close to 3/4", so there not going to flex much & wrap up, it applies all the force on the rear so it plants itself.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: SRD Assassin Traction Device. is anybody useing them?? [Re: joedust451] #1007774
06/06/11 02:03 PM
06/06/11 02:03 PM
mopar65 Offline OP
mopar65  Offline OP
hi joe no i dont have the caltracs yet. i want to get the compleat kit but dont have the money right now. i was just interested in these because they say you can use them with mopar super stock spring and calvert says you cant. if i had the money i would just have a set of coil springs and ladder bars put on my car.so was just interested in hearing if anybody was running a set of them.thanks Bobby
Re: SRD Assassin Traction Device. is anybody useing them?? [Re: mopar65] #1007775
06/06/11 02:54 PM
06/06/11 02:54 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
I would NOT use Super Stock springs, they weigh a TON.....
save your money and buy the Calvert springs they are nice and light...
a Caltrac set up with the Caltrac Mono springs are prob LIGHTER than just the Super Stock spring...way better
ALSO what are your goals with this car??? Super Stock spring and a good rear shock ...i have been in the 9's with that alone. Caltracs though can be a lot lighter, a lot lower sitting, and can handle a LOT more power down the road if thats your plan....and also better re-sale value later on. BUT if you are budget racing right now...nothing wrong with what you have
....BAD A$$ STREET CAR.....
Re: SRD Assassin Traction Device. is anybody useing them?? [Re: n20mstr] #1007776
06/06/11 06:13 PM
06/06/11 06:13 PM
mopar65 Offline OP
mopar65  Offline OP
are you the one that has the fast 73 dodge dart? If so i love your car.Frist let me say i am not a bracket racer. I coulod not cut a good lite to save my life.lol i just like to go out and have fun and race my car.but my goal is to get my car to run 10 flat in the 1/4 but drive it on the street once in a while on pump gas if possable. which i know i wont beable to do with this 440 i have now.I dont have a lot of money so i only race or work on it when i have money.but i would be happy if i could run some 10.40 in the 1/4. i have ran a best of 10.68 at 125 in my mostly stock body 73 dodge dart.but the day i ran my 10.68 pass my best 60 foot was only a 1.54-1.55. which bi guess is not bad but should be faster right? i dont have the money for the caltract kit right now. thats why i was asking about the other kit in this post.but i think i am just going to do like you and joedust said and save my money to buyt he calvert kit. also hopefully nexy year i want to build a 512 for the dart.also if you can run 9 with super stock springs loooks like i have a long way to go before i need a diffrent set up. thanks for the help guys. mopar65
Re: SRD Assassin Traction Device. is anybody useing them?? [Re: mopar65] #1007777
06/06/11 06:21 PM
06/06/11 06:21 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have run mid nines on super stocks and mp gas shocks. Bigtime runs the setup you are looking at and likes them alot. I run cal tracs now and rancho shocks. I bent the front segment of the super stock springs after about 7 years of runing them.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: SRD Assassin Traction Device. is anybody useing them?? [Re: 1967dartgt] #1007778
06/06/11 06:26 PM
06/06/11 06:26 PM
Missouri
Challenger Offline
Challenger  Offline
Missouri
Bobby
Here is more information on them and guys that are using them. www.yellowbullet.com/forum/showthread.php?t=330723
Re: SRD Assassin Traction Device. is anybody useing them?? [Re: Challenger] #1007779
06/06/11 08:31 PM
06/06/11 08:31 PM
mopar65 Offline OP
mopar65  Offline OP
Bobby
hi kevin thanks for the link.sounds like a lot of people like it. but hey you might want to delete your link. there is some stuff in there the mods might not like.lol dont want to see you get in trouble.but i do like the girl that likes to jump up and down. so looks like i have some to with what way i want to go with my car. thanks again eevry one. mopar65
Re: SRD Assassin Traction Device. is anybody useing them?? [Re: mopar65] #1007780
06/06/11 10:13 PM
06/06/11 10:13 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
If you do not have the cal-tracs already then get the assasin bars when you get the money together.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: SRD Assassin Traction Device. is anybody useing them?? [Re: Dap] #1007781
06/06/11 11:51 PM
06/06/11 11:51 PM
N
N
yes i have the 73 dart....i would not say its fast, but i run it in 8.50 index and its just a street car.
What i would do with your car is conentrate on getting the 60' down. Porbably the best thing you can do is try to contol the rear end travel with a good set of shocks. They will work now and later on with other set ups. There are a lot of cheapo things you can do to get the car to plant the tire and move forward instead of UP like Super Stock springs like to do. Clamps, shock tuning and front suspension tuning also will get you a lot.
Another thing, 73's are some very heavy A body to begin with, try to lighten the car and try to get the front and rear the same weight, Whatever you take off the front move to the rear, Get the weight to 50/50 if you can, that will also help a lot. 125 you can prob got 10.30's work on the 60 and dont forget....instead of moving up, get the car to move forward....imagin if 2" of rise instead of 4" of rise....2" less up. 2" more forward
Re: SRD Assassin Traction Device. is anybody useing them?? [Re: n20mstr] #1007782
06/07/11 01:43 PM
06/07/11 01:43 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
You can also use the Landrum mono leaf springs with the SRD bars.
Nautilus Racing-
Re: SRD Assassin Traction Device. is anybody useing them?? [Re: Chris2581] #1007783
06/07/11 02:11 PM
06/07/11 02:11 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Have you got the calvert shocks, i've just bought a pair and on extension, they are very easy to pull out by hand compared to the ce shocks i've just took off.
If they improve the car i will let you know.
Mine only 60 ft's between 1.48-50 best 1.46.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
