Need Master Cylinder recommendation - A-body #1007671
06/06/11 01:13 AM
06/06/11 01:13 AM
Vista, California
ChickMaggot Offline OP
Vista, California
Guys,
I need an MC for a brake upgrade I'm doing.
I'm going from drum/drum to disc/drum on a '74 Duster. Got all the parts with the exception of the MC.
I'd like to go manual discs on the front to save as much room as possible for the 440. Right now, all I can seem to find in the way of MC's are for power disc brakes.
Can I use one designed for power brakes or do I need to get an actual manual brake unit?
My first time doing this swap. Can ya help a brutha out?
Maggot
You can lead a gift horse to water, but you
can't look in his mouth.
Re: Need Master Cylinder recommendation - A-body [Re: ChickMaggot] #1007672
06/06/11 01:43 AM
06/06/11 01:43 AM
grande prairie , ab , canada
68notch Offline
68notch  Offline
walked into a auto parts store and ordered one for my 68 barracuda , manual with front discs , after i changed from front drums
theres nothing as permanent as a temporary fix 70 super bee 79 red express 67 fargo 8o aspen rt
Re: Need Master Cylinder recommendation - A-body [Re: 68notch] #1007673
06/06/11 02:20 AM
06/06/11 02:20 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
I use the same piece of iron. works fine.
Re: Need Master Cylinder recommendation - A-body [Re: west] #1007674
06/06/11 09:34 AM
06/06/11 09:34 AM
ill
dennismopar73 Offline
ill
i use a MC OFF 1980 dodge truck with disc/drum no power brand new was 36$ lightweight same as the 100$ piece they try to sell you
jmo
Re: Need Master Cylinder recommendation - A-body [Re: ChickMaggot] #1007675
06/06/11 09:42 AM
06/06/11 09:42 AM
charlotte,nc
pyp1000 Offline
pyp1000  Offline
charlotte,nc
I use a disc/drum mc from a volare on my barracuda. works fine.
Re: Need Master Cylinder recommendation - A-body [Re: 68notch] #1007676
06/06/11 11:21 AM
06/06/11 11:21 AM
Vista, California
Vista, California
This would seem to be the easiest way. Unfortunately, I'm dealing with kids who don't even know the difference between a "long block" and a "short block" and who have never even heard of a Duster.
Re: Need Master Cylinder recommendation - A-body [Re: ChickMaggot] #1007677
06/06/11 02:55 PM
06/06/11 02:55 PM
Marion,Indiana
Seth_Jones Offline
Seth_Jones  Offline
Marion,Indiana
I got mine from O'reillys if that helps any.
Re: Need Master Cylinder recommendation - A-body [Re: ChickMaggot] #1007678
06/06/11 03:35 PM
06/06/11 03:35 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..when we bore our engines we use bigger pistons.
..when a master cyl is rebuilt the same size rubber pistons are used and can sometimes leak.
.. make sure it's a new unit.
.. i like Master Power stuff...very hi quality.
Re: Need Master Cylinder recommendation - A-body [Re: can.al] #1007679
06/06/11 04:21 PM
06/06/11 04:21 PM
scratchnfotraction Offline
best way is to use a 4 bolt to 2 bolt adaptor on the firewall and use a newer style 2 bolt alum MC from mid 80s car/truck
gives much more room with the BB in A-bodys
dr diff sells a nice adaptor,MP sells one,you can even get an offset one for a hemi in an A-body
I used the mp adaptor and adjustable brake rod from master power brake
used the 73 manual disc brakes with 11x2.5 rear drums on my 68 Dart
I used the stock 2 bolt alum MC off the power brake set up on my 88 truck and made my own 4 bolt to 2 bolt alum plate for firewall support to go manual brakes,manual steer,manaul shift with the 440 in the truck
Re: Need Master Cylinder recommendation - A-body [Re: can.al] #1007680
06/06/11 04:26 PM
06/06/11 04:26 PM
If your current (drum/drum) M/C is good keep it! Take off the lines from it & stick a drill bit deep into the brass cone in the half closest to the firewall as that is the half that will power the front discs and if there is no residual pressure valve (RPV) you are set & it's just a piece of neoprene on top of a spring & you'll feel the springiness if it is there. Disc/drum M/C's have a larger reservoir in the rear (disc) half as discs do use a bit more fluid vol when applied as opposed to a wheel cyl & if grandma does not have her M/C checked regularly it could eventually get low enough to run out of enough fluid during a panic stop and the resulting lawsuit could b disastrous but for enthusiasts such as ourselves who keep fluid levels topped off you'll be fine. If you do have to get a M/C make sure the tapered inside recess of the rear piston (it's like a thimble) has a shallow recess for the neoprene retainer on the pushrod to lock into and Manual brake M/C's must have this piston recess but mistakes do happen and I would contact Doc for the right bore size to get, though I have a 1&1/8" bore M/C on a disc (74)/drum (10") on a 65 dart & no probs & I (re)used the OE drum/drum splitter which is not the way it is supposed to b done but stops perfect & no excessive front pad (semi mets) wear.
Re: Need Master Cylinder recommendation - A-body [Re: ChickMaggot] #1007681
06/08/11 02:46 AM
06/08/11 02:46 AM
Vista, California
Vista, California
Seth, thanks for the part number. Went down and ordered one today and will pick it up tomorrow.
Seemed like the best option. No adapters, mods, etc. Just bolt on and go. I knew it was an option on the car, just couldn't find the reman part number.
For anyone interested - Kragen/O'Rielly, Cardone #10-1627
Maggot
Re: Need Master Cylinder recommendation - A-body [Re: ChickMaggot] #1007682
06/09/11 12:03 AM
06/09/11 12:03 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
If your car has a 2 bolt master cyl. on it already, would you still need the adapter? I'm thinking not, but thought Iwould throw it out there. I have a 63 Valiant.
Re: Need Master Cylinder recommendation - A-body [Re: None2Slow] #1007683
06/09/11 12:10 AM
06/09/11 12:10 AM
Vista, California
Vista, California
It'll be a straight R&R for me. Can't get easier than that.
Maggot
Re: Need Master Cylinder recommendation - A-body [Re: None2Slow] #1007684
06/09/11 07:39 AM
06/09/11 07:39 AM
measure the bolt spaceing on the MC and compair it to the newer style alum bolt spaceing.
dont that 63 MC only have 1 line from it?
you would have to add in the other lines to go with it.
Re: Need Master Cylinder recommendation - A-body [Re: scratchnfotraction] #1007685
06/09/11 08:46 PM
06/09/11 08:46 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Yes it only has 1 line. I have to change it all up anyways as I am adding wilwood disks for the 9" drum spindles. The rear drums are from a Ford Maverick as is the rear. I figured I would do it while the engine is out.
