Trans update ***pictures*** #1007629
06/06/11 12:27 AM
06/06/11 12:27 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
well started the process of yanking the trans. Got under the car and the tail shaft is in about 5 pieces. Looked back w/ the light as I was pulling the x-member bolts and it appears it puked a cap on the drive shaft. That's why I felt the vibration get stronger and stronger I guess. Still going to pull it (maybe tomorrow) and see if anything else broke. Might not of even been the trans. every thing is done except the convert bolts and rear u-joit. It's a mess for sure.
Coming soon!!!!
Re: Trans update *** [Re: Mr.Yuck] #1007630
06/06/11 02:24 AM
06/06/11 02:24 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Sounds like you got very lucky you and your car made the pass safe.
How do you like the cowl on your car? Can you double stack your air cleaners with that?
Re: Trans update *** [Re: Mr.Yuck] #1007631
06/06/11 03:12 AM
06/06/11 03:12 AM
Cab_Burge Online work
Cab_Burge  Online Work
Make sure and check the output shaft for straightness before reusing it Second thing is to make sure that the trans is the only thing hurt
Re: Trans update *** [Re: Cab_Burge] #1007632
06/06/11 09:12 AM
06/06/11 09:12 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
"How do you like the cowl on your car? Can you double stack your air cleaners with that?"
Yes I could stack 2, going to run a 3" K&N. I like it. I will look better when it's body color.
Yeah the trans is going to get yanked and inspected. Still might upgrade while it's out.
Re: Trans update *** [Re: Mr.Yuck] #1007633
06/06/11 09:16 AM
06/06/11 09:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I had a friends 66 Coronet that lost a cap last year. It bent the output shaft big time.
Doug
Re: Trans update *** [Re: Mr.Yuck] #1007634
06/06/11 09:23 AM
06/06/11 09:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
All that just for a simple little U-joint... bummer
Re: Trans update *** [Re: MR_P_BODY] #1007635
06/06/11 09:38 AM
06/06/11 09:38 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
one
Re: Trans update *** [Re: Mr.Yuck] #1007636
06/06/11 09:38 AM
06/06/11 09:38 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
2
Re: Trans update *** [Re: Mr.Yuck] #1007637
06/06/11 09:39 AM
06/06/11 09:39 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
three
Re: Trans update *** [Re: Mr.Yuck] #1007638
06/06/11 10:06 AM
06/06/11 10:06 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
Ouch! I'll bet it's gonna have a bent tailshaft Good thing you didn't have a mishap after that let go!
Re: Trans update *** [Re: dc426] #1007639
06/06/11 10:54 AM
06/06/11 10:54 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
no kidding. Good thing I have a drive shaft loop! I think it was bouncing off of it and that's the only reason it didn't come completly apart.
Re: Trans update ***pictures*** [Re: Mr.Yuck] #1007640
06/06/11 12:45 PM
06/06/11 12:45 PM
Q
Quicktree Offline
Quicktree  Offline
Q
did anyone mention pinion angle
Re: Trans update ***pictures*** [Re: Quicktree] #1007641
06/06/11 01:08 PM
06/06/11 01:08 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I knew you could be counted on
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Trans update *** [Re: Mr.Yuck] #1007642
06/06/11 01:56 PM
06/06/11 01:56 PM
Tampa Florida
dc426 Offline
dc426  Offline
Tampa Florida
Hunter let me know what you will need. I have a ton of 727 stuff.
dc
Re: Trans update *** [Re: dc426] #1007643
06/06/11 04:03 PM
06/06/11 04:03 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
dc
will do. Thanx.
and yes I will be checking the pinion angle
Re: Trans update ***pictures*** [Re: dusturbd340W5] #1007644
06/06/11 07:39 PM
06/06/11 07:39 PM
Q
Quicktree Offline
Quicktree  Offline
Q
heck somebody has to say it
Re: Trans update ***pictures*** [Re: Mr.Yuck] #1007645
06/06/11 10:55 PM
06/06/11 10:55 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
are u using solid u-joints??
Re: Trans update ***pictures*** [Re: rickraw] #1007646
06/07/11 09:30 AM
06/07/11 09:30 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
no should I be?
Coming soon!!!!
Re: Trans update ***pictures*** [Re: Mr.Yuck] #1007647
06/07/11 11:25 AM
06/07/11 11:25 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
no should I be?
I run solid u joints. When I had my drive shaft cut and rebuilt, the shop owner told me that solids are at least 3 times stronger than an equal sized grease-able joint.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Trans update ***pictures*** [Re: bigsbigelow] #1007648
06/07/11 11:48 AM
06/07/11 11:48 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
no should I be?
The u-joint didn't break the cap fell off...I guess maybe the clip broke or something. The joint looks fine except for the missing cap and some marks from the loop
Coming soon!!!!
