Header gaskets that actually seal? #1007527
06/05/11 10:02 PM
06/05/11 10:02 PM
North Central Florida
E
eightlitermopar Offline OP
E
Still hunting down my tick/tapping noise, I thought I would double gasket my headers to see if any noise disappears
The headers are heddman elites, so thick flange...but there might be a leak...I dunno.
I don't think they leak, but it's worth a shot. I am trying everything before I need to pull the motor to poke around and see what I can find....
eight
Mopar or no car
Re: Header gaskets that actually seal? [Re: eightlitermopar] #1007528
06/05/11 10:13 PM
06/05/11 10:13 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I use the cheap white paper mr. gasket ones, but I put some effort into making the welded bead sealing surface on the header as flat as I could get it. Easy to do if the headers aren't in the car already.....
What you can try is to add a thin smear of hi-temp copper rtv sealer to ANY brand of gasket to make them seal. The only drawback is it can be messy and time consuming to clean the old rtv off later on down the road.
The most bullet proof setup I know of is using copper header gaskets, and the copper rtv at the same time. Pretty much no way to hurt the copper gaskets and all you have to do is wire brush the old copper rtv off and apply a new coating if you ever have to take it apart.
Re: Header gaskets that actually seal? [Re: Neil] #1007529
06/05/11 10:16 PM
06/05/11 10:16 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
if it is a headers gasket sealing problem - REMFLEX.COM is the only way to go.
but them from amazon to save a ton, but they will seal it for sure!
Re: Header gaskets that actually seal? [Re: DJVCuda] #1007530
06/05/11 10:25 PM
06/05/11 10:25 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
NAPA NITRO SEALS are the best I have found. they are made with a lot of graphie and a soft enough to fill any imperfections. you can put them in the flame of a cutting torch and they will not burn.
from the pics Iv seen they look a lot like Rimflex gaskets..
I am truckless..
Re: Header gaskets that actually seal? [Re: Neil] #1007531
06/06/11 12:07 AM
06/06/11 12:07 AM
X2, that first
Re: Header gaskets that actually seal? [Re: eightlitermopar] #1007532
06/06/11 12:08 AM
06/06/11 12:08 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
take them off, and carefully remove the gaskets. if you have a leak, you should see the carbon tracking, across the gasket. did you remove the extra metal between the tubes, from the flange? i cut off the flanges between the tubes, allowing me to move the individual tubes if needed. also allows extra room around the spark plugs. i also hit the header flange faces with a file before putting them on, to make sure they're really flat and will seal. you might also look carefully at the collectors. sometimes they leak, but the noise will sound like the flanges leaking.
Re: Header gaskets that actually seal? [Re: DJVCuda] #1007533
06/06/11 08:57 AM
06/06/11 08:57 AM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
yep, what he said!!
Re: Header gaskets that actually seal? [Re: eightlitermopar] #1007534
06/06/11 09:05 AM
06/06/11 09:05 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Get a 4 or 5' long piece of 1/4" tubing and use it to listen to your motor while it's running. Hold one end up to your ear and the other end move it around your header flanges. It works well and will pin point any leaks.
Re: Header gaskets that actually seal? [Re: Challenger 1] #1007535
06/06/11 09:11 AM
06/06/11 09:11 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We use Mr Gasket ultras.Even seal with the cheap Summit headers.Ive even reused them.I also cut the flanges on my TTIs even though they are thick.It does give you a bit more room.Just dont do what one guy I know did.He cut the flange between 4&6 3&5 Had to have them fixed.I did get a chuckle out of that.Rocky
Chrysler Firepower
Re: Header gaskets that actually seal? [Re: therocks] #1007536
06/06/11 09:28 AM
06/06/11 09:28 AM
GA
Boosted Offline
Boosted  Offline
GA
I have used Summit Racing Copper Gaskets with out any problems.. So far so good...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Header gaskets that actually seal? [Re: eightlitermopar] #1007537
06/06/11 09:35 AM
06/06/11 09:35 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
Throw away the gaskets, and use high temp RTV.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Header gaskets that actually seal? [Re: Boosted] #1007538
06/06/11 09:37 AM
06/06/11 09:37 AM
ill
dennismopar73 Offline
ill
i dont use gaskets, little high temp sealer good to go,,
but i make sure my headers are flat, save me lots of money
Re: Header gaskets that actually seal? [Re: therocks] #1007539
06/06/11 01:25 PM
06/06/11 01:25 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Another vote for Mr. Gasket Ultra's. And I've reused them also.
Re: Header gaskets that actually seal? [Re: rapom] #1007540
06/06/11 04:37 PM
06/06/11 04:37 PM
Dalton, MA
Slipknot440 Offline
Slipknot440  Offline
Dalton, MA
I went with copper gaskets on my hemi. Nothing else seemed to work for me
Re: Header gaskets that actually seal? [Re: Slipknot440] #1007541
06/06/11 06:28 PM
06/06/11 06:28 PM
Eastern Shore of Maryland
N
nasty68 Offline
nasty68  Offline
N
I don't use gaskets, haven't for awhile. I use permatex "The Right Stuff". Never have any leaks.
68 dart, 383, 727
2013 Jeep JKU Sahara
Re: Header gaskets that actually seal? [Re: nasty68] #1007542
06/06/11 09:12 PM
06/06/11 09:12 PM
Central NC
gch Offline
gch  Offline
Central NC
Having a flat surface on the flange is more important than any gasket IMO.
That being said I have had the best luck with the plain old fel pro blue gaskets.Re use them at least once and never had a leak.
Re: Header gaskets that actually seal? [Re: gch] #1007543
06/07/11 12:24 AM
06/07/11 12:24 AM
E
E
thanks for the input guys! this post will have to be cut and pasted into my computer car file.
As I said, I am not even sure if it is a header leak at this point. The Heddman header flange seemed to be straight and pretty thick when put on the car.
BUT...if my tapping noise is coming from my tranny.... then I will have to remove the headers to--- 1) pull the motor and tranny, or 2)drop the tranny from underneath.
either way, I see a lot of swearing in my future, and I want to put it all together right!!
thanks again guys!
eight
Mopar or no car
Re: Header gaskets that actually seal? [Re: eightlitermopar] #1007544
06/07/11 12:31 AM
06/07/11 12:31 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
One word...Cometic.
The set of Cometics I have, have been on 2 different motors, headers on and off numerous times. No leaks, tears, etc.
They CANNOT be beat!!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Header gaskets that actually seal? [Re: eightlitermopar] #1007545
06/07/11 12:31 AM
06/07/11 12:31 AM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
i had leaky header gaskets on my 440, i bought 2 sets of the cheap Mr. Gasket's header gasket , i glued both sets together with rtv black, old school trick, let them set overnight, no leaks , however, i am using the exhaust studs instead of header bolts, works great
