Header gaskets that actually seal?
#1007527
06/05/11 10:02 PM
06/05/11 10:02 PM
Posts: 1,630 North Central Florida
eightlitermopar
Still hunting down my tick/tapping noise, I thought I would double gasket my headers to see if any noise disappears The headers are heddman elites, so thick flange...but there might be a leak...I dunno. ![](/ubbthreads/images/graemlins/shruggy.gif) I don't think they leak, but it's worth a shot. I am trying everything before I need to pull the motor to poke around and see what I can find.... eight
Mopar or no car
Re: Header gaskets that actually seal?
[Re: DJVCuda]
#1007530
06/05/11 10:25 PM
06/05/11 10:25 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
NAPA NITRO SEALS are the best I have found. they are made with a lot of graphie and a soft enough to fill any imperfections. you can put them in the flame of a cutting torch and they will not burn.
from the pics Iv seen they look a lot like Rimflex gaskets..
I am truckless..
[Re: eightlitermopar]
#1007532
06/06/11 12:08 AM
06/06/11 12:08 AM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
take them off, and carefully remove the gaskets. if you have a leak, you should see the carbon tracking, across the gasket. did you remove the extra metal between the tubes, from the flange? i cut off the flanges between the tubes, allowing me to move the individual tubes if needed. also allows extra room around the spark plugs. i also hit the header flange faces with a file before putting them on, to make sure they're really flat and will seal. you might also look carefully at the collectors. sometimes they leak, but the noise will sound like the flanges leaking. ![](/ubbthreads/images/graemlins/scope.gif)
[Re: DJVCuda]
#1007533
06/06/11 08:57 AM
06/06/11 08:57 AM
Posts: 625 Florida-West Coast
Thor500
Florida-West Coast
if it is a headers gasket sealing problem - REMFLEX.COM is the only way to go.
but them from amazon to save a ton, but they will seal it for sure!
yep, what he said!! ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Challenger 1]
#1007535
06/06/11 09:11 AM
06/06/11 09:11 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
We use Mr Gasket ultras.Even seal with the cheap Summit headers.Ive even reused them.I also cut the flanges on my TTIs even though they are thick.It does give you a bit more room.Just dont do what one guy I know did.He cut the flange between 4&6 3&5 Had to have them fixed.I did get a chuckle out of that.Rocky
Chrysler Firepower
[Re: therocks]
#1007536
06/06/11 09:28 AM
06/06/11 09:28 AM
Posts: 2,648 GA
Boosted
GA
I have used Summit Racing Copper Gaskets with out any problems.. So far so good...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
#1007537
06/06/11 09:35 AM
06/06/11 09:35 AM
Posts: 1,051 Slidell, La.
doctor_mopar
Slidell, La.
Throw away the gaskets, and use high temp RTV.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: gch]
#1007543
06/07/11 12:24 AM
06/07/11 12:24 AM
eightlitermopar
thanks for the input guys! this post will have to be cut and pasted into my computer car file.
As I said, I am not even sure if it is a header leak at this point. The Heddman header flange seemed to be straight and pretty thick when put on the car.
BUT...if my tapping noise is coming from my tranny.... then I will have to remove the headers to--- 1) pull the motor and tranny, or 2)drop the tranny from underneath.
either way, I see a lot of swearing in my future, and I want to put it all together right!!
thanks again guys!
eight
Mopar or no car
#1007544
06/07/11 12:31 AM
06/07/11 12:31 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
One word...Cometic. The set of Cometics I have, have been on 2 different motors, headers on and off numerous times. No leaks, tears, etc. They CANNOT be beat!! ![](/ubbthreads/images/graemlins/thumbs.gif)
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
#1007545
06/07/11 12:31 AM
06/07/11 12:31 AM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
i had leaky header gaskets on my 440, i bought 2 sets of the cheap Mr. Gasket's header gasket , i glued both sets together with rtv black, old school trick, let them set overnight, no leaks , however, i am using the exhaust studs instead of header bolts, works great ![](/ubbthreads/images/graemlins/Twocents.gif)
