Cooling fan controls
#1006679
06/04/11 05:30 PM
06/04/11 05:30 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
I am putting my car back on the street and I need to install a fan control that is automatic.What do you guys use? Summit brand,Painless,Hayden,Derale,Be Cool... I want it on at 190 and off at 170 and am not sure weather the threaded sender is better or the bulb unit that fits into the radiator fins. Thanks Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Cooling fan controls
[Re: OzHemi]
#1006681
06/04/11 05:47 PM
06/04/11 05:47 PM
fourgearsavoy
Rittman Ohio
Thanks OZ Summit sells one for a single fan that looks like a direct copy of the Spal unit I will stop by Summit tomorrow and compare them all. Gus
[Re: 1340busa]
#1006686
06/05/11 08:37 AM
06/05/11 08:37 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
adjustable is nice I suppose when you're trying to tune where you want it, but if you're going back to street driving, I imagine you'll be setting it and forgetting it.
all you need is a relay from the junk yard. for example, Dakota's have a relay on the inner fender for the Fog lights, if the truck has fogs.
then use a grounding sending unit to ground the control circuit of the relay. you can buy just the sending unit for around $30-40 and there are lots of options available. I have a 180 degree stat and found a sender that's 195 on, 185 off. Then I was really sly and wired it into a spare slot in the factory power distribution box on my Dakota, so that it looks factory and I don't have an extra relay bolted to the side of my inner fender.
**Photobucket sucks**
