Cooling fan controls #1006679
06/04/11 05:30 PM
06/04/11 05:30 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I am putting my car back on the street and I need to install a fan control that is automatic.What do you guys use? Summit brand,Painless,Hayden,Derale,Be Cool...
I want it on at 190 and off at 170 and am not sure weather the threaded sender is better or the bulb unit that fits into the radiator fins.
Gus
64 Plymouth Savoy
Dana 60
Re: Cooling fan controls [Re: fourgearsavoy] #1006680
06/04/11 05:40 PM
06/04/11 05:40 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I use a Spal controller to run my dual Spal fans and am very happy with it.
You can set it to any temp you want for turn on, low and high speed, off, etc.
Re: Cooling fan controls [Re: OzHemi] #1006681
06/04/11 05:47 PM
06/04/11 05:47 PM
Rittman Ohio
Rittman Ohio
Thanks OZ Summit sells one for a single fan that looks like a direct copy of the Spal unit I will stop by Summit tomorrow and compare them all.
Gus
64 Plymouth Savoy
Dana 60
Re: Cooling fan controls [Re: fourgearsavoy] #1006682
06/04/11 05:52 PM
06/04/11 05:52 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
As much as I like and use Summit... I got the Spal controller from Speedway...can't remember why though
I have it in the glove box...that is it on the right hand side.
Re: Cooling fan controls [Re: OzHemi] #1006683
06/04/11 09:53 PM
06/04/11 09:53 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i got one of the summit kits for my hhr fan and it works flawlessly. came with a relay, sensor and wiring, pretty affordable too
Re: Cooling fan controls [Re: dirtybee] #1006684
06/04/11 10:24 PM
06/04/11 10:24 PM
Rittman Ohio
Rittman Ohio
I have an HHR fan that I will be using along with a belt drive stock type water pump.I did have a CV electric pump that worked well on the track and around town but not good on the hi-way.
Gus
64 Plymouth Savoy
Dana 60
Re: Cooling fan controls [Re: fourgearsavoy] #1006685
06/05/11 12:25 AM
06/05/11 12:25 AM
georgia
1340busa Offline
1340busa  Offline
georgia
i bought one from advance auto that fits into the radiator and it works great.
Re: Cooling fan controls [Re: 1340busa] #1006686
06/05/11 08:37 AM
06/05/11 08:37 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
adjustable is nice I suppose when you're trying to tune where you want it, but if you're going back to street driving, I imagine you'll be setting it and forgetting it.
all you need is a relay from the junk yard. for example, Dakota's have a relay on the inner fender for the Fog lights, if the truck has fogs.
then use a grounding sending unit to ground the control circuit of the relay. you can buy just the sending unit for around $30-40 and there are lots of options available. I have a 180 degree stat and found a sender that's 195 on, 185 off. Then I was really sly and wired it into a spare slot in the factory power distribution box on my Dakota, so that it looks factory and I don't have an extra relay bolted to the side of my inner fender.
**Photobucket sucks**
Re: Cooling fan controls [Re: fourgearsavoy] #1006687
06/05/11 06:02 PM
06/05/11 06:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I like the Derale #16759, it's adjustable and has a core temp probe.
http://www.summitracing.com/parts/DER-16759/
Re: Cooling fan controls [Re: fourgearsavoy] #1006688
06/06/11 12:43 AM
06/06/11 12:43 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Get a SPAL controller. I have been running one on my car for a few years with no problems. I use them on any car I set up with electric fans.
Re: Cooling fan controls [Re: Azzkikrcuda] #1006689
06/06/11 02:29 AM
06/06/11 02:29 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
I as well run dual hd spals and mine came with painless relays.
Ive the 160 sending unit that goes in intake that kicks one fan on (clearly I could have both) and a toggle to run both.
Re: Cooling fan controls [Re: quick77rt ] #1006690
06/06/11 02:39 AM
06/06/11 02:39 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
On my Spal controller, I just used the factory LS1 sending unit to trigger it. Then just program it from there....I have the low speed for the first fan come on at around 185°, and full speed for it, and trigger for the second fan (second fan is relay controlled and not variable speed like the primary fan) to come on at 210°ish.
It also has an input for an a/c trigger...I used a trianary switch when I did the air con setup in the car and when turned on it kicks automatically kicks the second cooling fan on as well.
Re: Cooling fan controls [Re: OzHemi] #1006691
06/06/11 05:54 AM
06/06/11 05:54 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Gus you can see I use the stock waterpump and fan and then I also have an electric fan as a pusher. But I only use the electric fan if stuck in traffic on real hot days to keep it below 200 if it creeps up over 200 when stuck in traffic for a while. I just have my fan on a toggle switch that I switch on when I need it. And it is ign control so in case I forget to turn it off it will go off when I turn the key off. Ron
