Clutch disc diameter for Big Block. #1006133
06/03/11 11:38 PM
06/03/11 11:38 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
What would the correct clutch disc diameter be for a 143 tooth flywheel used on a 383? I want to score a centerforce assy. for my car. The pressure plate shows just one application but the disc shows two applications for a big block. 10.5 and 11.0. Which is correct and why would there be two applications. I recall running into a similar situation many years ago but forget the details?
Also, where is the best place to get centerforce equipment at a good price?
Re: Clutch disc diameter for Big Block. [Re: 70mopes] #1006134
06/04/11 09:59 AM
06/04/11 09:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
143 tooth wheel uses an 11" clutch , make sure it's NOt a 10.95 which is a scalloped PP for the 10.5 hat pattern
Re: Clutch disc diameter for Big Block. [Re: JohnRR] #1006135
06/04/11 10:53 AM
06/04/11 10:53 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Charlie-
Here is the Centerforce package you would use:
http://brewersperformance.com/proddetail.asp?prod=CDF1123
McCleod performance diaphragm package similar to Centerforce, but is a scalloped pressure plate which allows the larger 11.95 disc on the 143 tooth flywheel:
http://brewersperformance.com/proddetail.asp?prod=MCDP1123
Both packages are in stock, ready to ship
Wayne
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
