Charlie-
Here is the Centerforce package you would use:
http://brewersperformance.com/proddetail.asp?prod=CDF1123
McCleod performance diaphragm package similar to Centerforce, but is a scalloped pressure plate which allows the larger 11.95 disc on the 143 tooth flywheel:
http://brewersperformance.com/proddetail.asp?prod=MCDP1123
Both packages are in stock, ready to ship
Wayne
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
