Back in the saddle tomorrow. #1006057
06/03/11 10:13 PM
06/03/11 10:13 PM
Columbus, Ohio
wheelsup68dart Offline OP
Columbus, Ohio
Hopefully will finish up car tomorrow and get to the race track to see if all is well since the accident at trails 2 weeks ago. Picked up my converter tonight and got my driveshaft checked, and all is okay. Hopefully the motor will fire without problem and I can make some shakedowns to ensure the chassis still works okay. I will be doing the 1/8th mile thing for starters. It has been a busy 2 weeks but here is what I have done.
Step 1. Remove old transmission and converter
2. Have converter inspected and driveshaft tested
3. Install new rear slicks
4. remove diff cover and inspect ring and pinion(okay)
5. Pulled the axels and inspect for twist(okay)
6. Replace rear rotors and pads
7.Install left front fender and realign the front fenders and bumper on mounting brackets.
8. realign and new dzus tabs on front end to resquare hood.
9. Use my bottle jack to push quarter panel back into shape and allow the deck lid to be refastened.
So all that is left is to install A+A brake valve body in fresh transmission, and reinstall in car. Put fluid in, and see if vehicle fires okay.
Wish me luck, results to be posted tomorrow. If I have time I may install my new terminator button and make some bottom bulb hits too.
Re: Back in the saddle tomorrow. [Re: wheelsup68dart] #1006058
06/03/11 10:19 PM
06/03/11 10:19 PM
Super Scamp Offline
Super Scamp  Offline
Keep the hard work going.. almost there!!! good luck testing..
Mopar Mafia Racing..
Just One Man's Opinion Mopar Mafia Racing
Re: Back in the saddle tomorrow. [Re: Super Scamp] #1006059
06/03/11 10:24 PM
06/03/11 10:24 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I hope all goes smoothly for ya
Re: Back in the saddle tomorrow. [Re: wheelsup68dart] #1006060
06/03/11 10:28 PM
06/03/11 10:28 PM
Guitar Jones Offline
Cool, good to hear and hope it all goes well for you. I'm still curious about why the brake engaged though, did you ever come up with a reason why?
