diagnoses and cure please #1005718
06/03/11 07:50 AM
06/03/11 07:50 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
My 383 runs rich when you start it up and seems not to hit on all eight but once it is good and warm it will run fine. Have a lot of smoke out the back when you start it up until it runs for awhile. I think it has something to do with the choke. What do you guys think? Thanks
Re: diagnoses and cure please [Re: 70 buzz] #1005719
06/03/11 07:55 AM
06/03/11 07:55 AM
sw michigan
TB3CUDA Online content
TB3CUDA  Online Content
sw michigan
you need to take it out and open it up,blow the carbon out of it.just idling around will make it load up.hope to see ya at k&m next weekend
Re: diagnoses and cure please [Re: 70 buzz] #1005720
06/03/11 11:25 AM
06/03/11 11:25 AM
IMGTX Offline
IMGTX  Offline
What color is the smoke?
Black is too much fuel. The choke may need adjustment or a new choke pulloff/dashpot.
What Make, year, model, and Carburetor?
Re: diagnoses and cure please [Re: 70 buzz] #1005721
06/03/11 04:15 PM
06/03/11 04:15 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
...not enough initial timing and or weak spark...
...probably need to change your plugs now too!
Re: diagnoses and cure please [Re: 70 buzz] #1005722
06/03/11 04:31 PM
06/03/11 04:31 PM
Southern CA
Colin Frolick Offline
Southern CA
choke is staying on too long, adjust it to close less / open sooner and agree to check the vacuum pull-off
