Got Car Scaled Today #1005514
06/02/11 10:42 PM
06/02/11 10:42 PM
HOUSTON,TEXAS
FIREGUY12 Offline OP
HOUSTON,TEXAS
Well I got my car scaled at the chassis shop among other things. Its a 71 Plymouth Duster Back halfved car with Coil Overs all the way around. CAPS auto front end. weighed 3001 lbs with me in it. This car is all steel and glass windows including the hood. Only fiberglass is the front bumper. Just wanted to know what front and rear % some other A body cars have compared to mine. Mine is as follows. 50% front 46% Rear.
total front weight 1527
Total rear weight 1396
Re: Got Car Scaled Today [Re: FIREGUY12] #1005515
06/02/11 10:57 PM
06/02/11 10:57 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
that only = 96% where is the other 4%
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Got Car Scaled Today [Re: FIREGUY12] #1005516
06/02/11 11:03 PM
06/02/11 11:03 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Mine is 55% front --45% rear.....how did you lose the 4% on the rear??
I would like to lose that on the FRONT!!
Also,,mine weighs 3291 with driver...all steel/all original glass,,,fiberglass hood,,full interior, carpet, etc...driver is 216#..
If you like drag racing, support your local track.
Re: Got Car Scaled Today [Re: FIREGUY12] #1005517
06/02/11 11:06 PM
06/02/11 11:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You lost 4% some where
Re: Got Car Scaled Today [Re: FIREGUY12] #1005518
06/02/11 11:10 PM
06/02/11 11:10 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
How do u like the front end
Re: Got Car Scaled Today [Re: one bad fish] #1005519
06/02/11 11:17 PM
06/02/11 11:17 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
OOPs. 54% front 46% on rear. As for the front end seems like nice stuff once you get everything squared up and figured out. My only concern is how the front tires move while backing up then straighten back when driving forward.
Re: Got Car Scaled Today [Re: one bad fish] #1005520
06/02/11 11:18 PM
06/02/11 11:18 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
And your a lightweight at 78#
Re: Got Car Scaled Today [Re: FIREGUY12] #1005521
06/02/11 11:20 PM
06/02/11 11:20 PM
bronx n.y
O
O
bronx n.y
U to I have the same front end
Re: Got Car Scaled Today [Re: one bad fish] #1005522
06/03/11 12:09 AM
06/03/11 12:09 AM
HOUSTON,TEXAS
HOUSTON,TEXAS
Ok I miss undersood the % readings. 50.8% of the weight is on the front 50.8% of 3001 lbs. is on the front. 46.8 % is on the rear of 3001 lbs. this is with me ib the car. Im 200 lbs. So the car is 2801 lbs. without me. I will post the print out later.
Re: Got Car Scaled Today [Re: FIREGUY12] #1005523
06/03/11 12:25 AM
06/03/11 12:25 AM
HOUSTON,TEXAS
HOUSTON,TEXAS
Here are the weights. Now I understand. Left is the total weight of the left side of the car 1527 lbs. Front weight is 1396 lbs. So if you add the front weights LF 857 lbs.+ RF 749 lbs.=1606 lbs. which is 53.5% on the front. Rear weight LR 670 lbs. + RR 726 lbs.=1396 lbs. which is 46.5 % on the rear.53.5%+46.5%=100%
Re: Got Car Scaled Today [Re: FIREGUY12] #1005524
06/03/11 12:28 AM
06/03/11 12:28 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I dont know how i did it..but mine is 51% front 49% rear
Re: Got Car Scaled Today [Re: 70blackfish] #1005525
06/03/11 12:44 AM
06/03/11 12:44 AM
HOUSTON,TEXAS
HOUSTON,TEXAS
Here is the actual print out.
Re: Got Car Scaled Today [Re: 70blackfish] #1005526
06/03/11 12:47 AM
06/03/11 12:47 AM
HOUSTON,TEXAS
HOUSTON,TEXAS
Thats almost a 50/50 car. I bet your car works real good. may have to add a few pounds to the rear to get m car to do what I want. We will see this weekend. I should have some in car video as well as outside.
Re: Got Car Scaled Today [Re: 70blackfish] #1005527
06/04/11 04:52 AM
06/04/11 04:52 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Same here, though the car is heavy and has aluminium block, heads etc. Tried to keep stuff as light as possible on the front.
These E bodys make it a bit easier by making everything from the bulkhead back extra heavy
