Re: Got Car Scaled Today
[Re: FIREGUY12]
#1005516
06/02/11 11:03 PM
06/02/11 11:03 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Mine is 55% front --45% rear.....how did you lose the 4% on the rear?? I would like to lose that on the FRONT!! Also,,mine weighs 3291 with driver...all steel/all original glass,,,fiberglass hood,,full interior, carpet, etc...driver is 216#..
If you like drag racing, support your local track.
[Re: FIREGUY12]
#1005517
06/02/11 11:06 PM
06/02/11 11:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Well I got my car scaled at the chassis shop among other things. Its a 71 Plymouth Duster Back halfved car with Coil Overs all the way around. CAPS auto front end. weighed 3001 lbs with me in it. This car is all steel and glass windows including the hood. Only fiberglass is the front bumper. Just wanted to know what front and rear % some other A body cars have compared to mine. Mine is as follows. 50% front 46% Rear. total front weight 1527 Total rear weight 1396
You lost 4% some where
[Re: FIREGUY12]
#1005518
06/02/11 11:10 PM
06/02/11 11:10 PM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
How do u like the front end
[Re: one bad fish]
#1005519
06/02/11 11:17 PM
06/02/11 11:17 PM
Posts: 513 HOUSTON,TEXAS
FIREGUY12
HOUSTON,TEXAS
OOPs. 54% front 46% on rear. As for the front end seems like nice stuff once you get everything squared up and figured out. My only concern is how the front tires move while backing up then straighten back when driving forward.
[Re: FIREGUY12]
#1005521
06/02/11 11:20 PM
06/02/11 11:20 PM
one bad fish
bronx n.y
U to I have the same front end
[Re: FIREGUY12]
#1005523
06/03/11 12:25 AM
06/03/11 12:25 AM
FIREGUY12
HOUSTON,TEXAS
Here are the weights. Now I understand. Left is the total weight of the left side of the car 1527 lbs. Front weight is 1396 lbs. So if you add the front weights LF 857 lbs.+ RF 749 lbs.=1606 lbs. which is 53.5% on the front. Rear weight LR 670 lbs. + RR 726 lbs.=1396 lbs. which is 46.5 % on the rear.53.5%+46.5%=100%
[Re: 70blackfish]
#1005527
06/04/11 04:52 AM
06/04/11 04:52 AM
Posts: 2,916 A shed in England
Tig
A shed in England
I dont know how i did it..but mine is 51% front 49% rear
Same here, though the car is heavy and has aluminium block, heads etc. Tried to keep stuff as light as possible on the front. These E bodys make it a bit easier by making everything from the bulkhead back extra heavy
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
