Re: 1971 Dodge Demon Stripe Kits!! NEED PICTURES [Re: ademon] #1005448
06/03/11 12:56 PM
06/03/11 12:56 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Not too sure on the side stripes also
I agree with abemon. I've been noticing this for about a year or so. It all started with that blue one that was in MCG... The one with the crazy wide/deep rear rims and rubberband tires. Something just doesn't look "right" about the stripes. The OP's picture from the side looks sort of suspicious too. The stripe, top and bottom halves are not identical, perhaps the reproductions are. Maybe I'm just crazy, but abemon's and mine look right, others do not. When you buy a set of reproduction stripes, are they left and right side specific because I believe the originals are.
Re: 1971 Dodge Demon Stripe Kits!! NEED PICTURES [Re: pinkduster] #1005449
06/03/11 01:00 PM
06/03/11 01:00 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I think the OP's stripes are on the wrong sides and therefore, upside down. Or maybe I'm
Re: 1971 Dodge Demon Stripe Kits!! NEED PICTURES [Re: pinkduster] #1005450
06/03/11 01:10 PM
06/03/11 01:10 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
the width of my side stripes top and bottom on center above the rear wheel opening is 2 5/32". How wide are yours Pinkduster? in the pic they look wider than mine.
Re: 1971 Dodge Demon Stripe Kits!! NEED PICTURES [Re: ademon] #1005451
06/03/11 06:15 PM
06/03/11 06:15 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Okay, I measured the stripes on my quarter panels. I'm working by myself so I don't have anybody to hold the tape measure for me. I'm trying to go off the center of the rallye wheel center cap. The bottom stripe is 2 5/32, but the top stripe looks more like 2 3/16. At the front edge of the quarter where the stripe stops and goes into the door jamb, I get 1 5/32 on the bottom stripe and 1 1/16 on the top stripe. Its the beginning of the stripe that usually catches my eye. The bottom stripe is slightly fatter in the beginning and I think the whole "arc" is slightly different from top to bottom.
Re: 1971 Dodge Demon Stripe Kits!! NEED PICTURES [Re: pinkduster] #1005452
06/03/11 10:17 PM
06/03/11 10:17 PM
New Jersey
U_Code_Cuda Offline OP
New Jersey
OK,
Just ordered a new kit from Performance Car Graphics!! After talking with Dave there he told me that the quarter panel stripe is different from right to left and if the kit I have does not state right or left the stripe would look wrong! My kit quarter stripes are identical??? Of course upon removal...tail panel came off perfect and quarter pulled some clear off!!
Just thought after all the money into restoration why not make the car look correct!! I wish I thought of that 2 years ago when I bought the POS!! stripe kit.
As for the quarter stripe Dave stated that the stripe should not touch the flare in the quarter!! I have seen stripes both ways so what is correct and what looks better
I personally like it not touching so that is the way I am going but, then again once the stripe gets here it probable will go on exactly the same as the last stripe knowing my luck!!
1970 R/T Challenger 4-speed
1971 Demon 340 3-speed
Re: 1971 Dodge Demon Stripe Kits!! NEED PICTURES [Re: ademon] #1005453
06/03/11 10:34 PM
06/03/11 10:34 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Dave at PERFORMANCE CAR GRAPHICS is the absolute best in the business. He's been making stripes for Mopars for over 25 years.
When you receive your stripe kit, not only will each piece have the date of manufacture, but it will be marked "top" , "bottom", "left", "right", etc...very strict attention to detail. They will also come with instructions as well as photos and measurements for placement.
I will never buy my stripe kits from any other manufacture...ever!
CHECK OUT MY NEW WEB SITE !
Re: 1971 Dodge Demon Stripe Kits!! NEED PICTURES [Re: anlauto] #1005454
06/03/11 10:55 PM
06/03/11 10:55 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Cool! That means I'm NOT crazy.
I'm sure factory placement varied to a degree. My original stripes do come down slightly into the flare, but do not get near the actual lip.
Most of the stripes I ever got for my other cars are from Performance car graphics. They've always been a pleasure to deal with.
Re: 1971 Dodge Demon Stripe Kits!! NEED PICTURES [Re: U_Code_Cuda] #1005455
06/04/11 09:13 AM
06/04/11 09:13 AM
Port Saint Lucie, FL
ChallengerGary Offline
who did you buy the stripes from, the rear is not right
http://cgi.ebay.com/ebaymotors/ws/eBayIS...e=STRK:MEWAX:IT
I am thinking of just replacing the rear stripe since, Phoenix told me there side stripe kit will come down that low on the quarters also??? The only company I see that sells the correct rear stripe looks like performance car graphics...
how is fellow Moparts member ChallengerGary's stripe kits...but again not correct tail stripe with back drop for demon....
I mark my Demon side stripes with D and P on all of the pieces because there is a slight difference between the arc of the qtr panel stripes and the top and bottom sections of the fender and door stripes are not truly symmetrical either. My tail panel is the 72 style without the little "dip" for the Demon Decal placement. I could easily add that to mine if someone gave me accurate measurements on size and placement.
Re: 1971 Dodge Demon Stripe Kits!! NEED PICTURES [Re: U_Code_Cuda] #1005456
06/05/11 01:17 AM
06/05/11 01:17 AM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Unrestored original stripes
Re: 1971 Dodge Demon Stripe Kits!! NEED PICTURES [Re: formula_s] #1005457
06/05/11 01:20 AM
06/05/11 01:20 AM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Survivor. Open attachments and enlarge.
Re: 1971 Dodge Demon Stripe Kits!! NEED PICTURES [Re: formula_s] #1005458
06/05/11 10:39 AM
06/05/11 10:39 AM
None
71rm23 Offline
71rm23  Offline
None
VERY nice formula_S
