Pinion Snubbers #1005305
06/02/11 03:36 PM
06/02/11 03:36 PM
Nanaimo, B.C.
GwaiiEagle Offline OP
Mannix
Mannix
Nanaimo, B.C.
Using a B body 8-3/4 rear end in a Duster.
Axle wrap is extreme and I'm hoping to reduce this with a snubber.
Would clearance be an issue with an aftermarket snubber, like MP's or Mancini's? The Mancini piece looks like it is worth the extra $20.
Re: Pinion Snubbers [Re: GwaiiEagle] #1005306
06/02/11 03:38 PM
06/02/11 03:38 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Put the right springs on it and use the pinion snubber for what it does best. Door stop.
Re: Pinion Snubbers [Re: GomangoCuda] #1005307
06/02/11 04:00 PM
06/02/11 04:00 PM
Nanaimo, B.C.
Mannix
Mannix
Nanaimo, B.C.
My racing budget, what's left of it will not take the hit.
If I have a budget of 150$ (race winnings) and bad wrap I'll have to pony up for the snubber or maybe scrounge up a set of traction bars.
The car had this old setup seen below. The bottom leafs are only halfs with a pad at the end. Where they bolt on can be adjusted as shown below.
Re: Pinion Snubbers [Re: GwaiiEagle] #1005308
06/02/11 04:05 PM
06/02/11 04:05 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Go the traction-bar route before the snubber
Re: Pinion Snubbers [Re: dOrk !] #1005309
06/02/11 04:08 PM
06/02/11 04:08 PM
Kirkland, Washington
Pacnorthcuda Offline
What if he overloads the trunk with beer?
Re: Pinion Snubbers [Re: Pacnorthcuda] #1005310
06/02/11 04:49 PM
06/02/11 04:49 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
to that suggestion ...
It is a BESTer choice than that snubber !
Re: Pinion Snubbers [Re: GwaiiEagle] #1005311
06/02/11 05:20 PM
06/02/11 05:20 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
As long as the existing wild spring setup is anchored, and not ready to fall apart, you can put the adjustable snubber on it and adjust it 1/2 inch from floor and try it. You will be greatly annoyed by the street manners after that though.
Re: Pinion Snubbers [Re: GomangoCuda] #1005312
06/02/11 07:49 PM
06/02/11 07:49 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
But in the mean time clamp the front spring segments tight with some heavy duty spring clamps.
The one you have on there is worthless IMHO
Can be home made on the cheap
1.389 60' 002 & 003 S/S springs NO SNUBBER foot braking
Re: Pinion Snubbers [Re: roadhazard] #1005313
06/02/11 09:15 PM
06/02/11 09:15 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Back in the mid 80's, I didn't have much money and ended up useing 3/4 ton chevy truck springs mixed with the originals. The springs were 50 bucks at a junk yard, and new center pins. I ran 8 leafs on the left and 9 on the right. In front of the axle and 3 leafs out the back. I kept the first leaf stock, then added every other truck leaf. Being sure to stagger them 2-3 inches back with each leaf, for the first 4 or so. Didnt even need a snubber and ride height was about 1 inch higher. I used a 069 J converter and 391 gears in a 72 cuda with a 9-1 comp 440 and stock heads. Went 11.96 for a best I believe but the 60' was a 1.49/1.52 3800 lb car. Cam and intake selection wasn't all that good back then and an 11 sec street car was tough to beat. L60 mickey tires and 3 inch exhaust. I'd launch on the primaries then stab the gas, or it wouldnt hook with the street tires back then
Re: Pinion Snubbers [Re: roadhazard] #1005314
06/02/11 10:17 PM
06/02/11 10:17 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I have read about adding extra clamps to the front portion of the leaf spring pack in several mopar magazine articles over the years. Spring clamps are dirt cheap too!
Re: Pinion Snubbers [Re: Neil] #1005315
06/03/11 09:20 AM
06/03/11 09:20 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
doesn't the pinion rotate up though on launch? with the shorter leaves on the bottom of the stack, as the axle rotates, isn't it pushing the shorter, bottom leaves up into the top main leaf? how would clamps help anything there as it's trying to twist the axle upward? that motion would be pressing the leaves together anyway.
I thought you wanted the leaves on the back section so that as the front rotates upward, it helps to prevent the leaves from separating from each other?
**Photobucket sucks**
