A-833 4 speed Input shaft bearing #1005093
06/02/11 09:13 AM
06/02/11 09:13 AM
Boston, MA
crocha617 Offline OP
Boston, MA
How difficult is it to change the input shaft bearing on a 1970 a-844 trans I've never taken one apart before? This trans was in a friends car and he said it worked and shifted perfectly but was starting to hum in front and he recommended I put an input shaft bearing in it before I install it in my car. I am pretty mechanical and am sure I can do it but I'm just wondering if the whole thing needs to come apart or is it as simple as just removing the front bearing retainer? Or should I just drop it off and have completely gone through by a reputable shop? What's the going rate for a complete overhaul these days?
Re: A-833 4 speed Input shaft bearing [Re: crocha617] #1005094
06/02/11 09:23 AM
06/02/11 09:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The bearing can be replaced without complete disassembly , I did it many moons ago , BUT since it's out of the car I would have it gone thru , my experience it's usually the rear bearing that gets more beat up than the front .
Re: A-833 4 speed Input shaft bearing [Re: JohnRR] #1005095
06/02/11 10:20 AM
06/02/11 10:20 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The bearing doesn't come out from the front unless you have an 18 spline trans.
Assuming you don't, you have to pull off the side cover, pull out the tailstock and pull the mainshaft and let the cluster drop to the bottom of the case. You also have to remove the front bearing retainer so you can remove the snapring. You'll need a complete gasket kit.
If you're mechanically inclined then a complete rebuild is a piece of cake once you have all the parts "in hand" but you do need a special snapring tool (Sears). The toughest part of the job is installing the tailstock bushing - best taking it to a tranny shop and slipping the guy $5 !!
Re: A-833 4 speed Input shaft bearing [Re: Stanton] #1005096
06/02/11 10:43 AM
06/02/11 10:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
HUH ??? if pulling the input shaft AND it's a 23 spline then yes one would have to take the trans apart, but since the front part of the bearing sticks out the front of the case your statement is incorrect because the bearing is already poking out the front of the case.
Maybe it's the the fact that the input shaft won't come out the front on a 23 spline that I was able to pull the bearing off without disassembling the trans, I popped off the snap rings and used 2 screw drivers against the case and was able to pull off the bearing. You'd be amazed what a 17yr old with a set of tools and a natural mechanical aptitude can do.
Re: A-833 4 speed Input shaft bearing [Re: JohnRR] #1005097
06/02/11 12:32 PM
06/02/11 12:32 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Take it apart and fix it right. Regardless of 23 or 18 spline, the input shaft will not come out the front without dropping the cluster.
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: A-833 4 speed Input shaft bearing [Re: 64dodge572] #1005098
06/02/11 02:13 PM
06/02/11 02:13 PM
Boston, MA
Boston, MA
It's a 23 spline and all I want to do is change the input shaft bearing. I was hoping to confirm if I could just unbolt the front bearing retainer and switch the bearing out. The trans works great and shifts perfectly. I'm trying to get the car running for the summer and didn't want to send it out for a total rebuild that could take weeks.Thanks.
Re: A-833 4 speed Input shaft bearing [Re: crocha617] #1005099
06/02/11 08:15 PM
06/02/11 08:15 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
According to everybody ... NO. According to John-boy, yes - but then he tends to condradict everyone.
Who you want to believe is up to you. Personally, and I've done a few and I've NEVER had an input bearing come off the shaft (or go on again) without significant effort. If I ever had one slip on or off with as little effort as John's did I think I'd throw the shaft away.
Re: A-833 4 speed Input shaft bearing [Re: Stanton] #1005100
06/02/11 08:31 PM
06/02/11 08:31 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
John is correct here. It can be done-no sweat. 18 or 23 spline-doesn't matter.
Here is how.
-Take the bearing retainer off.
-take the external and internal snap rings off.
-wedge two prybars against the case and pry by way of the external groove.
-while you have it "loaded" with the prybars(pulled slightly away from the case) have an assistant tap on the pilot end of the input shaft rearward with a brass hammer. keep the pressure on the bars while tapping continuously. Don't worry, it won't take too much tapping effort. Bearing comes off.
-Install is easy. If you have the ability to warm the bearing, do it, but not necessary. Place the bearing on the shaft and using a blunt nosed drift punch tap around at the inner race of the bearing until its seated.
-Install snap rings and retainer and you are done.
MB
Re: A-833 4 speed Input shaft bearing [Re: Stanton] #1005101
06/02/11 08:35 PM
06/02/11 08:35 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I can be done John's way but it will require some finesse with an air chisel with a blunt rounded tip.Hard to describe the backyard way but it's still doubtful that it ONLY needs an input bearing
Gus
64 Plymouth Savoy
Dana 60
Re: A-833 4 speed Input shaft bearing [Re: JohnRR] #1005102
06/02/11 08:37 PM
06/02/11 08:37 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
You forgot the part about, we didn't know you couldn't/shouldn't do it that way so we just did.
Ahhh the good old days.
Careful, your character's showing!
Re: A-833 4 speed Input shaft bearing [Re: 64dodge572] #1005103
06/02/11 09:17 PM
06/02/11 09:17 PM
ky.
K
kenworth_goose Offline
K
ky.
Dan
This is untrue. Just took my 23 spline OD apart and removed the front input shaft bearing from the front then took the rest out the back WITHOUT dropping the cluster.
Re: A-833 4 speed Input shaft bearing [Re: kenworth_goose] #1005104
06/03/11 09:58 AM
06/03/11 09:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Dan
The OD trans doesn't impress me, I was able to pull the bearing off the mainshaft, and put it back on by hand , same for the rear bearing on a 727 .
Re: A-833 4 speed Input shaft bearing [Re: crocha617] #1005105
06/03/11 10:50 AM
06/03/11 10:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No you can't just swap it like that, would be nice if one could but it's not that easy. What makes your friend it's the front bearing?
Buy the rebuild kit and you can do it yourself it's not that hard .
Re: A-833 4 speed Input shaft bearing [Re: JohnRR] #1005106
06/03/11 12:49 PM
06/03/11 12:49 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Original Poster
JohnRR
JohnRR
Which JohnRR do I agree with? or is it disagree with? Oh heck I don't know.
Re: A-833 4 speed Input shaft bearing [Re: GomangoCuda] #1005107
06/03/11 01:01 PM
06/03/11 01:01 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
He is trying to say it is not as easy as just unbolting the bearing retainer, removing the bearing by hand, swap bearing and bolt the retainer back on with little effort involved (like you can do with a Tremec or BW T5).
Re: A-833 4 speed Input shaft bearing [Re: 70440+6bbl] #1005108
06/03/11 01:33 PM
06/03/11 01:33 PM
GomangoCuda Offline
GomangoCuda  Offline
Ok, it' not that easy but it certainly is not difficult. The only reason I did it was because I was already there (replacing broken bearing retainer) and thought why not? If the bearing had actually been shot I would have done a rebuild instead.
Re: A-833 4 speed Input shaft bearing [Re: GomangoCuda] #1005109
06/03/11 01:57 PM
06/03/11 01:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Original Poster
JohnRR
JohnRR
It's your call obviously.
As said above it's not as simple as one might hope , obviously depends on how tight the press fit it , I do remember it took a bit of work to get it off and get it back on because of the press fit.
I would be opening that trans up to see how it looks and regasket it at minimum , see hown much junk flushes out .
