Take it apart and fix it right. Regardless of 23 or 18 spline, the input shaft will not come out the front without dropping the cluster.
Dan
This is untrue. Just took my 23 spline OD apart and removed the front input shaft bearing from the front then took the rest out the back WITHOUT dropping the cluster.
