Does anyone make a quality mechanical voltage regulator #1004624
06/01/11 07:30 PM
06/01/11 07:30 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
I've had 2 NAPA replacements on my dad's 68 charger and neither has lasted. The car passes every other electrical test showing all the parts, wiring, grounds, alternator and everything are good. The car is a stock 68 318 car other than a 4bbl carb added with the engine rebuild.
I'll convert to the later electronic unit and dual field alternator if needed, but would prefer to stick with the original style parts if there is a decent one available.
Thanks,
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: Does anyone make a quality mechanical voltage regulator [Re: blown340] #1004625
06/01/11 07:37 PM
06/01/11 07:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
There are two versions out there, one is the original style truly mechanical regulator the other is an electronic version that bolts in it's place, not to be confused with the later style regulator.
I have been running the mechanical style for more than 10 years on my 65 Cuda with nary an issue. But I doubt the ones sold today are as good.
Don't be the exception.
Re: Does anyone make a quality mechanical voltage regulator [Re: Supercuda] #1004626
06/01/11 07:51 PM
06/01/11 07:51 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Do you know who makes the ones with the electronic guts?
Thanks,
-Jon
Re: Does anyone make a quality mechanical voltage regulator [Re: blown340] #1004627
06/01/11 08:13 PM
06/01/11 08:13 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Are you sure you have NAPA mechanical units? How heavy are they? If light they are electronic. If they have some mass to it, it mechanical. NAPA sells both kinds.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Does anyone make a quality mechanical voltage regulator [Re: HemiRick] #1004628
06/01/11 08:24 PM
06/01/11 08:24 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
The mechanical version NAPA sells has two screws to remove the cover to service the contacts(made in china) Just get an electronic one from where ever NAPA or Autozone then cut the screw tabs off the mechanical cover and glue it over the electronic one to make it look big.
1969 Hemi Roadrunner 2nd owner
Re: Does anyone make a quality mechanical voltage regulator [Re: 69hemibeep] #1004629
06/01/11 08:37 PM
06/01/11 08:37 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Its definitely the nice heavy mechanical one that I have.
Is the electronic one listed as a stock replacement so the counter guy will be able to find it, or do I need to ask for something specific?
Thanks,
-Jon
Re: Does anyone make a quality mechanical voltage regulator [Re: blown340] #1004630
06/01/11 09:05 PM
06/01/11 09:05 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I've read in the past that if you have upgraded to an electronic ignition (you didn't say you have, so I'm throwing this out for everyone), then you should also have an electronic regulator (I'm not up enough on my electrical theory to explain why). I have the electronic versions in the original style case on both my old cars (both with electronic ignitions).
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Does anyone make a quality mechanical voltage regulator [Re: GO_Fish] #1004631
06/01/11 09:13 PM
06/01/11 09:13 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Hmmm... interesting. The car does have a pertronix on it.
Re: Does anyone make a quality mechanical voltage regulator [Re: blown340] #1004632
06/01/11 09:56 PM
06/01/11 09:56 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i've used the VR101 from Car Quest and never had an issue, even with electronic ignition. they're made by Standard. Year One has the electronic version.
Re: Does anyone make a quality mechanical voltage regulator [Re: 69hemibeep] #1004633
06/01/11 10:17 PM
06/01/11 10:17 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The electronic ones are avaliable at just abour any parts store.You can even put the old cover over them.Have them on 3 cars.Just as good as the new style dual field ones.My sons 62 300 has been on 10 years.Still charges great.Running electronic ign with one is fine.The 62 ran the OE mech one for almost 4 years with the MP electronic ign.Rocky
Chrysler Firepower
Re: Does anyone make a quality mechanical voltage regulator [Re: therocks] #1004634
06/01/11 10:27 PM
06/01/11 10:27 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Thanks all, my local auto parts store has the electronic one. I'm going to pick one up in the morning and try it. I'll report back. Thanks for all the speedy replies!!
-Jon
Re: Does anyone make a quality mechanical voltage regulator [Re: blown340] #1004635
06/02/11 05:30 PM
06/02/11 05:30 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
-Jon
picked up the electronic one this morning, installed it, and its working perfectly. Thanks for all the help everyone.
Re: Does anyone make a quality mechanical voltage regulator [Re: blown340] #1004636
06/02/11 05:35 PM
06/02/11 05:35 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Glad it worked for you.Rocky
Chrysler Firepower
Re: Does anyone make a quality mechanical voltage regulator [Re: blown340] #1004637
06/04/11 03:02 PM
06/04/11 03:02 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
-Jon
What brand and part number did you get?
Re: Does anyone make a quality mechanical voltage regulator [Re: markz528] #1004638
06/04/11 05:52 PM
06/04/11 05:52 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Just go to any parts store.They should have them in stock.Ive used a few different brands.The on in the 62 is probally 12 years old and came fro AZ.Never a problem.I dont even know if any stores actually carry the point ones anymore.Rocky
Chrysler Firepower
Re: Does anyone make a quality mechanical voltage regulator [Re: markz528] #1004639
06/04/11 07:53 PM
06/04/11 07:53 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
A member has them in the b-body parts for sale.
mrrandyj
Reged: 20/01/03
Loc: CT Re: 70 Back - B Body Parts For Sale - June [Re: moparts]
#6664539 - 02/06/11 11:40 PM Reply Quote
What we have here is a brand new reproduction voltage regulator for a 1962-1969 Dodge Plymouth or Chrysler vehicle. This regulator looks almost exactly like what the originals look like from the outside, it even has the IGN and FLD stamped into the cover, but hidden inside is a small circuit board with diodes, transistors, and other electronic components. This voltage regulator is completely electronic. No more points that cause voltage fluctuations. Now you can have the best of both worlds, a voltage regulator that looks stock but is all electronic inside. This is a bolt on upgrade, no modifications are necessary. Bolt it on and plug in your factory wiring, its that simple. The cost for these is $28.00 each with free shipping anywhere in the continental US.
If you have any questions you can email me at mrrandyj@aol.com
Re: Does anyone make a quality mechanical voltage regulator [Re: GO_Fish] #1004640
06/04/11 07:58 PM
06/04/11 07:58 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
I've read in the past that if you have upgraded to an electronic ignition then you should also have an electronic regulator (I'm not up enough on my electrical theory to explain why).
The theory is that the rapid cycling of the mechanical points cause "noise" in the electrical system that the electronioc ignition doesn't like. Hasn't been my experience though.
Re: Does anyone make a quality mechanical voltage regulator [Re: John_Kunkel] #1004641
06/04/11 09:32 PM
06/04/11 09:32 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Thanks, John!
I can say that my GTS was going through mechanical regs at a fast clip, but changed to the electronic version and have had no further charging problems.
Re: Does anyone make a quality mechanical voltage regulator [Re: GO_Fish] #1004642
06/04/11 11:45 PM
06/04/11 11:45 PM
michigan woods
imfixinmopars426 Offline
michigan woods
had a mechanical one stick the points and overcharge,then heat burned stuff up,and then no charge...but when you drive a ol mopar cross country,you must carry spare parts,lol....get a electronic for more of a balanced voltage,imho..
Re: Does anyone make a quality mechanical voltage regulator [Re: imfixinmopars426] #1004643
06/05/11 03:01 AM
06/05/11 03:01 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Back in the old days the points stuck a lot causing overcharging which sometimes lead to the battery blowing up. I've got first hand experience on that..twice over.
