Does anyone make a quality mechanical voltage regulator
#1004624
06/01/11 07:30 PM
06/01/11 07:30 PM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
I've had 2 NAPA replacements on my dad's 68 charger and neither has lasted. The car passes every other electrical test showing all the parts, wiring, grounds, alternator and everything are good. The car is a stock 68 318 car other than a 4bbl carb added with the engine rebuild.
I'll convert to the later electronic unit and dual field alternator if needed, but would prefer to stick with the original style parts if there is a decent one available.
Thanks, -Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
Re: Does anyone make a quality mechanical voltage regulator
[Re: blown340]
#1004625
06/01/11 07:37 PM
06/01/11 07:37 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
There are two versions out there, one is the original style truly mechanical regulator the other is an electronic version that bolts in it's place, not to be confused with the later style regulator.
I have been running the mechanical style for more than 10 years on my 65 Cuda with nary an issue. But I doubt the ones sold today are as good.
[Re: Supercuda]
#1004626
06/01/11 07:51 PM
06/01/11 07:51 PM
blown340
Walnut Creek, CA
Do you know who makes the ones with the electronic guts?
Thanks, -Jon
[Re: blown340]
#1004627
06/01/11 08:13 PM
06/01/11 08:13 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Are you sure you have NAPA mechanical units? How heavy are they? If light they are electronic. If they have some mass to it, it mechanical. NAPA sells both kinds.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: 69hemibeep]
#1004629
06/01/11 08:37 PM
06/01/11 08:37 PM
blown340
Walnut Creek, CA
Its definitely the nice heavy mechanical one that I have.
Is the electronic one listed as a stock replacement so the counter guy will be able to find it, or do I need to ask for something specific?
Thanks, -Jon
[Re: blown340]
#1004630
06/01/11 09:05 PM
06/01/11 09:05 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I've read in the past that if you have upgraded to an electronic ignition (you didn't say you have, so I'm throwing this out for everyone), then you should also have an electronic regulator (I'm not up enough on my electrical theory to explain why). I have the electronic versions in the original style case on both my old cars (both with electronic ignitions).
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#1004631
06/01/11 09:13 PM
06/01/11 09:13 PM
blown340
Walnut Creek, CA
Hmmm... interesting. The car does have a pertronix on it.
[Re: 69hemibeep]
#1004633
06/01/11 10:17 PM
06/01/11 10:17 PM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
The electronic ones are avaliable at just abour any parts store.You can even put the old cover over them.Have them on 3 cars.Just as good as the new style dual field ones.My sons 62 300 has been on 10 years.Still charges great.Running electronic ign with one is fine.The 62 ran the OE mech one for almost 4 years with the MP electronic ign.Rocky
Chrysler Firepower
[Re: therocks]
#1004634
06/01/11 10:27 PM
06/01/11 10:27 PM
blown340
Walnut Creek, CA
Thanks all, my local auto parts store has the electronic one. I'm going to pick one up in the morning and try it. I'll report back. Thanks for all the speedy replies!! -Jon
[Re: blown340]
#1004635
06/02/11 05:30 PM
06/02/11 05:30 PM
blown340
Walnut Creek, CA
-Jon
picked up the electronic one this morning, installed it, and its working perfectly. Thanks for all the help everyone.
[Re: blown340]
#1004636
06/02/11 05:35 PM
06/02/11 05:35 PM
therocks
Niles , Ohio
Glad it worked for you.Rocky
Chrysler Firepower
[Re: markz528]
#1004638
06/04/11 05:52 PM
06/04/11 05:52 PM
therocks
Niles , Ohio
Just go to any parts store.They should have them in stock.Ive used a few different brands.The on in the 62 is probally 12 years old and came fro AZ.Never a problem.I dont even know if any stores actually carry the point ones anymore.Rocky
Chrysler Firepower
[Re: markz528]
#1004639
06/04/11 07:53 PM
06/04/11 07:53 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
A member has them in the b-body parts for sale. mrrandyj mopar Reged: 20/01/03 Loc: CT Re: 70 Back - B Body Parts For Sale - June [Re: moparts] #6664539 - 02/06/11 11:40 PM Reply Quote What we have here is a brand new reproduction voltage regulator for a 1962-1969 Dodge Plymouth or Chrysler vehicle. This regulator looks almost exactly like what the originals look like from the outside, it even has the IGN and FLD stamped into the cover, but hidden inside is a small circuit board with diodes, transistors, and other electronic components. This voltage regulator is completely electronic. No more points that cause voltage fluctuations. Now you can have the best of both worlds, a voltage regulator that looks stock but is all electronic inside. This is a bolt on upgrade, no modifications are necessary. Bolt it on and plug in your factory wiring, its that simple. The cost for these is $28.00 each with free shipping anywhere in the continental US. If you have any questions you can email me at mrrandyj@aol.com
[Re: imfixinmopars426]
#1004643
06/05/11 03:01 AM
06/05/11 03:01 AM
Posts: 4,230 State of retirement
52savoy
State of retirement
had a mechanical one stick the points and overcharge,then heat burned stuff up,and then no charge...but when you drive a ol mopar cross country,you must carry spare parts,lol....get a electronic for more of a balanced voltage,imho..
Back in the old days the points stuck a lot causing overcharging which sometimes lead to the battery blowing up. I've got first hand experience on that..twice over.
