Page 4 of 4 1 2 3 4
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Dunnuck Racing] #1003508
06/13/11 12:28 PM
06/13/11 12:28 PM
Finland
mopster Offline OP
mopster  Offline OP
Finland
No time for dyno, I have a race next weekend
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003509
06/13/11 12:41 PM
06/13/11 12:41 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
The reason I ask is,I was wondering what you used for an installed centerline? I tested an older version of the MP 4120657 camshaft in my 421. I played around with the camshaft timing to see what it would do. This was an older version,312-106 that has a .404 lobe lift instead of the current design.
I know a lot of people say to advance these camshafts a lot more than the MP recommendation, but with mine,it lost quite a bit of power past 104 installed. Every engine will be different,but I just thought I would pass it on.
Keith
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Dunnuck Racing] #1003510
06/13/11 02:39 PM
06/13/11 02:39 PM
Finland
mopster Offline OP
mopster  Offline OP
Finland
I have it at 104.
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Dunnuck Racing] #1003511
06/13/11 03:51 PM
06/13/11 03:51 PM
SoCal
Brian Hafliger Offline
SoCal
Keith
I'll pass this on as well since we're in the sharing mood...
Our engine we just did liked straight up best. This was on a 112lca.
Brian
Brian Hafliger
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Dunnuck Racing] #1003512
06/13/11 04:30 PM
06/13/11 04:30 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
Keith
Any info on the current design? I just installed the current .590 to try out and installed it on a 102. Will keep ya posted on what it likes.
Re: SB Edelbrock LA heads 304cfm@.600" [Re: abodiesonly1] #1003513
06/13/11 05:37 PM
06/13/11 05:37 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I've genereally found if the port cross section is relatively small compared the the cylinder swept volume (as is usually the case with a lot of wedge strokers), putting the cam in later helps the top end power, also an under-ported motor (if it has any decent compression) generally has an abundance of torque to begin with.
Advancing the cam generally works well when you've got plenty of port, adequate cam and compression but you're wanting to "use it all up" within a certain RPM limit.
WIZE
In Car:
Re: SB Edelbrock LA heads 304cfm@.600" [Re: abodiesonly1] #1003514
06/13/11 07:21 PM
06/13/11 07:21 PM
Northern Indiana
Northern Indiana
Mine is just an older version,with more lift.The valve opening/closing seat to seat and @.050 events are the same. I had it in at 101.5(aiming for 102) and it lost power across the entire range. I retarded it to 105 currently,and it is down a little but not nearly as bad,104 is the clear winner on mine.
Keith
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Dunnuck Racing] #1003515
06/14/11 12:09 PM
06/14/11 12:09 PM
Finland
mopster Offline OP
mopster  Offline OP
Finland
I actually considered advancing the cam because I have a little close ex valve/piston clearance, but I didnīt do it because I thought it would cost me power.
Hereīs another pic with the fuel system and air cleaners. A bit tall for a street motor?
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003516
06/14/11 02:11 PM
06/14/11 02:11 PM
SoCal
SoCal
Looks good!
Brian Hafliger
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003517
07/21/11 05:45 PM
07/21/11 05:45 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Itīs a 408 pump gas street engine with 10.7:1 CR, MP .590" flat tappet cam and 1.6 rockers
Any 1/4 mile hits with this thing yet?
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Quicktree] #1003518
07/21/11 07:36 PM
07/21/11 07:36 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
very nice I like the blacked out carb and valve covers.
i agree very sharp looking motor,the customer is gonna very pleased with the power also..sweet Brian
Re: SB Edelbrock LA heads 304cfm@.600" [Re: S/ST 3040] #1003519
07/22/11 02:00 AM
07/22/11 02:00 AM
Finland
mopster Offline OP
mopster  Offline OP
Finland
I have a race tomorrow at a decent track, Iīll report as soon as I get back.
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003520
08/02/11 06:40 PM
08/02/11 06:40 PM
Finland
mopster Offline OP
mopster  Offline OP
Finland
Ok, it ran 10.8 / 125mph. Itīs a 3300lbs street car with 727, dana60, 10" converter and no transbrake.
It was a very hot day, and also I didnīt get my 60ft times quite in the right zone since I only had chance to run four runs. All things considered I still think it was 1-2 tenths slower than I expected.
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003521
08/02/11 07:47 PM
08/02/11 07:47 PM
Northern Indiana
Northern Indiana
Don't feel bad,mine is slower than I would expect it to be too.
They never do what we would think they should and you still will find some e.t. with tuning I would bet.
Keith
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Brian Hafliger] #1003522
08/08/11 12:54 AM
08/08/11 12:54 AM
Sacramento
P
ptowntsi Offline
ptowntsi  Offline
P
Sacramento
That engine with those heads made 621HP this morning on pump gas. TQ was 541. Roller cam, 10.9:1, 1050, TTI 1 7/8 x 3.5" header.
just saw this in my car craft that came yesterday. very nice!
Page 4 of 4 1 2 3 4
