Re: SB Edelbrock LA heads 304cfm@.600"
[Re: Dunnuck Racing]
#1003512
06/13/11 04:30 PM
06/13/11 04:30 PM
Posts: 438 Great Lakes Region
abodiesonly1
Great Lakes Region
The reason I ask is,I was wondering what you used for an installed centerline? I tested an older version of the MP 4120657 camshaft in my 421. I played around with the camshaft timing to see what it would do. This was an older version,312-106 that has a .404 lobe lift instead of the current design. I know a lot of people say to advance these camshafts a lot more than the MP recommendation, but with mine,it lost quite a bit of power past 104 installed. Every engine will be different,but I just thought I would pass it on. Keith
Any info on the current design? I just installed the current .590 to try out and installed it on a 102. Will keep ya posted on what it likes.
[Re: abodiesonly1]
#1003513
06/13/11 05:37 PM
06/13/11 05:37 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
I've genereally found if the port cross section is relatively small compared the the cylinder swept volume (as is usually the case with a lot of wedge strokers), putting the cam in later helps the top end power, also an under-ported motor (if it has any decent compression) generally has an abundance of torque to begin with.
Advancing the cam generally works well when you've got plenty of port, adequate cam and compression but you're wanting to "use it all up" within a certain RPM limit.
[Re: Quicktree]
#1003518
07/21/11 07:36 PM
07/21/11 07:36 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
very nice I like the blacked out carb and valve covers.
i agree very sharp looking motor,the customer is gonna very pleased with the power also..sweet Brian
[Re: S/ST 3040]
#1003519
07/22/11 02:00 AM
07/22/11 02:00 AM
Posts: 128 Finland
mopster
Finland
Itīs a 408 pump gas street engine with 10.7:1 CR, MP .590" flat tappet cam and 1.6 rockers
Any 1/4 mile hits with this thing yet?
I have a race tomorrow at a decent track, Iīll report as soon as I get back.
[Re: Brian Hafliger]
#1003522
08/08/11 12:54 AM
08/08/11 12:54 AM
Posts: 10 Sacramento
ptowntsi
Sacramento
That engine with those heads made 621HP this morning on pump gas. TQ was 541. Roller cam, 10.9:1, 1050, TTI 1 7/8 x 3.5" header.
just saw this in my car craft that came yesterday. very nice!
