Having trouble with WOT #100344
08/05/08 09:22 PM
08/05/08 09:22 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
I'm sure that I'm overlooking something simple, however I noticed that I wasn't getting WOT, the butterflies in both the primaries and secondaries weren't all the way open once I put someone in the car to hold the pedal all the way down. I adjusted the throttle cable back and WOT looked in the carb, but now the idle is waaaay high (1800 rpms)! And I can't get the idle back down. The idle screw must not be touching the arm. Is the throttle cable too short? Or is there another way to get the idle back down to normal?
Re: Having trouble with WOT [Re: 68Bullit] #100345
08/05/08 09:27 PM
08/05/08 09:27 PM
hum-you might have to much carpet/insulation under your go pedal.if so,remove some and readjust cable.
Re: Having trouble with WOT [Re: 68Bullit] #100346
08/05/08 09:28 PM
08/05/08 09:28 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You need the mopar throttle adapter, the hole you've mounted the throttle cable stud to has a longer throw then the correct location so you either get a good idle or WOT but not both...
Re: Having trouble with WOT [Re: 68Bullit] #100347
08/05/08 09:32 PM
08/05/08 09:32 PM
Locomotion Offline
Locomotion  Offline
You might have a little bit of tension on the throttle cable at idle keeping it open. That won't allow the idle screw to close the throttle. Loosen up the bracket clamp and retighten when your cable is a bit loose.
I don't believe Holley throttle blades are suppose to be exactly 90* @ WOT. But the carb should have a built-in stop.
If you can't get it right, the throttle cable may not be the right one for your application.
Re: Having trouble with WOT [Re: Locomotion] #100348
08/05/08 10:18 PM
08/05/08 10:18 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
I'm beginning to think the same thing now. This cable has been broken and then crimped back in place. This doesn't look to great does it?
Re: Having trouble with WOT [Re: 68Bullit] #100349
08/05/08 11:25 PM
08/05/08 11:25 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
omg buy a new cable or pm me ill send you one ...
Re: Having trouble with WOT [Re: sogtx] #100350
08/06/08 10:42 PM
08/06/08 10:42 PM
wv
Dartcuda Offline
Dartcuda  Offline
wv
As said above , you need the holley adapter for mopars and a new throttle cable , probably less than $30 .
Re: Having trouble with WOT [Re: Dartcuda] #100351
08/10/08 10:10 PM
08/10/08 10:10 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Thanks Gentlemen. Where can I find this adaptor?
Re: Having trouble with WOT [Re: 68Bullit] #100352
08/10/08 10:35 PM
08/10/08 10:35 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Summit or jegs.
