ECM Mounting bracket #1002454
05/29/11 09:29 PM
05/29/11 09:29 PM
Gateway to the West.
hemi_harvester Offline OP
can anyone direct me to who might sell repro ECM mounting bracket like used on 72-74 B & E bodies ?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: ECM Mounting bracket [Re: hemi_harvester] #1002455
05/29/11 09:58 PM
05/29/11 09:58 PM
New Jersey Bada Bing
bremotorsports Offline
Go to my website (www.billrolikenterprises.com) and on the left side of the home page, click on the GREEN tab titled "SEARCH STORE".
Punch in 3513750 and you will see the bracket package!
Bill Rolik
Re: ECM Mounting bracket [Re: bremotorsports] #1002456
05/29/11 10:05 PM
05/29/11 10:05 PM
Re: ECM Mounting bracket [Re: bremotorsports] #1002457
05/30/11 02:18 PM
05/30/11 02:18 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Re: ECM Mounting bracket [Re: badblack68] #1002458
05/30/11 02:22 PM
05/30/11 02:22 PM
central new york
pettyblue440 Offline
central new york
who sells the one that bolts to the rear of the valley pan on a big block?
Re: ECM Mounting bracket [Re: hemi_harvester] #1002459
05/30/11 10:52 PM
05/30/11 10:52 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
besides being correct, what's the purpose of the bracket?
1972 Dodge Challenger
Re: ECM Mounting bracket [Re: PLUM_72] #1002460
05/30/11 11:25 PM
05/30/11 11:25 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
It allows for some airflow behind the ECU to keep it cooler. Most people who add the MP electronic ignition just bolt the ECU to the firewall. The factory thought there needed to be some extra cooling so they came up with that bracket.
With all the orange box failures I keep reading about, it makes me wonder if having them bolted dirrectly to the firewall is part of the problem.
Re: ECM Mounting bracket [Re: pettyblue440] #1002461
05/31/11 01:19 AM
05/31/11 01:19 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Rocket Restorations
Re: ECM Mounting bracket [Re: 6bblgt] #1002462
05/31/11 11:54 PM
05/31/11 11:54 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
one things for sure on the modules, sooner or later the gue will run down and out of the back causing
logan426
Re: ECM Mounting bracket [Re: MLR426] #1002463
06/01/11 12:17 AM
06/01/11 12:17 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You got that right. I was lucky that my origonal one waited until after it was removed and in a box before it decided to
