Indy valley cover #1001313
05/28/11 11:45 AM
05/28/11 11:45 AM
Burlington, Ontario Canada
Dave_S Offline OP
Dave_S  Offline OP
Anyone have any pix of an Indy two piece valley cover for a 440? Can it be installed with the heads on?
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Indy valley cover [Re: Dave_S] #1001314
05/28/11 11:58 AM
05/28/11 11:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The plate ends go under the edge of the head so I think you have to pull one .
Re: Indy valley cover [Re: Dave_S] #1001315
05/28/11 02:09 PM
05/28/11 02:09 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It can be slid in under the heads. Mine was a single piece cover that I had off more than once with the heads on. I tapped the center holes in the ends 3/8"NF. That way you could thread a bolt into the plate to break the seal between the front and back of the block. Then slide the plate back,twist it and drop down into the valley to remove.
Doug
Re: Indy valley cover [Re: Dave_S] #1001316
05/28/11 02:12 PM
05/28/11 02:12 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You going to indy heads Dave?
Re: Indy valley cover [Re: Dave_S] #1001317
05/28/11 03:57 PM
05/28/11 03:57 PM
Butler Pa. USA
rickma Offline
rickma  Offline
Butler Pa. USA
Like this ?
Re: Indy valley cover [Re: rickma] #1001318
05/28/11 04:53 PM
05/28/11 04:53 PM
Dave_S Offline OP
Dave_S  Offline OP
I'm looking to put a more substantial cover on my 512. I have tried a 440 source one piece and a Hughes two piece but they both leaked like a SOB. I think they flex too much from the crankcase pressure pulses caused by the big stroke. It doesn't have to be an Indy cover....just a solid set-up that wont require pulling a head to install.
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Indy valley cover [Re: Dave_S] #1001319
05/28/11 08:10 PM
05/28/11 08:10 PM
5th and plum
redmist Offline
redmist  Offline
5th and plum
AndyF Makes a real nice one.
Re: Indy valley cover [Re: Dave_S] #1001320
05/28/11 08:45 PM
05/28/11 08:45 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
With Eddy heads think it will sit right in there!
Re: Indy valley cover [Re: Dodgem] #1001321
05/28/11 08:51 PM
05/28/11 08:51 PM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
Use the solid indy cover,find a band saw with a adjustable table and fence.Set table to 45 degrees,set fence and cut it in half.Cheapest and a good seal with just rtv. Hope this helps.
Re: Indy valley cover [Re: Dave_S] #1001322
05/28/11 09:54 PM
05/28/11 09:54 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
It will be very hard to get it to seal completely leak free by sliding it in.I wouldn't waste money on a one piece unit though
Gus
64 Plymouth Savoy
Dana 60
Re: Indy valley cover [Re: fourgearsavoy] #1001323
05/28/11 10:09 PM
05/28/11 10:09 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Gus
X2..... I was bored and added an oil fill to mine
Mopar Performance
Re: Indy valley cover [Re: redmist] #1001324
05/28/11 10:14 PM
05/28/11 10:14 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Who sell's it?Any Do Andy have a website?
I've just replace my one piece cover this past weekend and wonder if it can be replace without removing a head So here is what i've did.Put a small bead of silicone on the front /rear of the block,small bead on the edge of the cover let it set until it gets flexible then slide it into position/wipe off excess silicone off the valley plate/head.Let it cure over night.No Leaks So Far.
Re: Indy valley cover [Re: moparniac] #1001325
05/28/11 10:24 PM
05/28/11 10:24 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Gus
Sledgehammer That's a nice looking plate the thing that i hate about the one peace deals r that if u have a engine plate u have to remove the plate to remove the cover It would be cool if someone sells one that u can remove the cover without removing the plate Care to share your details on how the pour spout was fab.in
Re: Indy valley cover [Re: DAYTONA540] #1001326
05/28/11 10:33 PM
05/28/11 10:33 PM
Dave_S Offline OP
Dave_S  Offline OP
HMMMMM bandsaw...I like that idea!
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Indy valley cover [Re: racerx] #1001327
05/28/11 10:39 PM
05/28/11 10:39 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
hole saw - http://www.speedwaymotors.com/search-oil-fill-cap.html - tap and some silicone I have it offset some cause of the intake and the way it is in there a quart of oil fits in there perfect and stays there nice and snug on it own while draining
Mopar Performance
Re: Indy valley cover [Re: moparniac] #1001328
05/28/11 10:51 PM
05/28/11 10:51 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thax.I'll be replacing my cover and adding one.
Re: Indy valley cover [Re: fourgearsavoy] #1001329
05/29/11 12:00 AM
05/29/11 12:00 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Gus
Mine never leaked or seeped a drop.
Doug
