493 what weight oil to use for street/strip #1000238
05/26/11 02:25 PM
05/26/11 02:25 PM
Illinois
saukvillage Offline OP
Illinois
I have a 493 big block with a hydraulic cam installed. I would like to know what type of motor oils are recommented for this motor. I plan on a little street/strip use at will. All information will be appreciated, thanks
Re: 493 what weight oil to use for street/strip [Re: saukvillage] #1000239
05/26/11 03:04 PM
05/26/11 03:04 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I woulds use Brad Pen 15/40 or 20/50.
other good oils are joe Gibbs, valvoline VR1 racing and Z-alt
http://chucker54.stores.yahoo.net/motoroil.html
Re: 493 what weight oil to use for street/strip [Re: Dodgem] #1000240
05/26/11 04:56 PM
05/26/11 04:56 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
10-40 or 20-50 depending on how your pressure is. Use zinc additive or high zinc racing oil like he said
Re: 493 what weight oil to use for street/strip [Re: radar] #1000241
05/26/11 05:08 PM
05/26/11 05:08 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I had 20w50 in my 493, Valvoline VR1. I just changed the oil for summer and went to 10w30.
The oil pressure with the 20w50 was 45-50 at freeway speeds and now sits at 40 with the thinner oil. It still idles with 35 psi. I wouldn't go thinner than 10w30 unless you drive a lot in the colder weather. As stated before, be certain to use a high ZINC oil.
Re: 493 what weight oil to use for street/strip [Re: Kern Dog] #1000242
05/26/11 05:50 PM
05/26/11 05:50 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
as thin of an oil that you can run while still maintaining good oil pressure. once it's good and broke in, a quality synthetic will be just fine.
add zinc too if you wish. how crazy is the cam? my dad has a small block with a pretty mild cam that uses softer spring rates on the valves, and he hasn't given a second thought to adding zinc, and has no problems. I think the zinc really becomes a factor when you get into big cams that need high spring pressures.
**Photobucket sucks**
Re: 493 what weight oil to use for street/strip [Re: Dodgem] #1000243
05/26/11 06:02 PM
05/26/11 06:02 PM
Illinois
Illinois
What about using shell Rotella T 15w40 diesel oil or better the Brad Penn 15w40, 20w50 weight oil.
Re: 493 what weight oil to use for street/strip [Re: saukvillage] #1000244
05/26/11 07:41 PM
05/26/11 07:41 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
AmsOil 10-40 and I hammer the 440.
