upper shock hardware #1000126
05/26/11 01:08 PM
05/26/11 01:08 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I've seen a few kits available from different companies. The ones I've seen include two stamped steel nuts. What are those for? Do they screw on after the main nut to act as a lock?
Does anyone have any survivor pictures of this? Thanks
Re: upper shock hardware [Re: burdar] #1000127
05/26/11 08:24 PM
05/26/11 08:24 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Re: upper shock hardware [Re: burdar] #1000128
05/26/11 09:27 PM
05/26/11 09:27 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
The stamped steel nut is used as a locknut. I don't have any pics of this set up on a survivor car. We have all of that hardware available on our website.
Re: upper shock hardware [Re: burdar] #1000129
05/26/11 09:31 PM
05/26/11 09:31 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
It screws on upside down ontop of the nut as a retainer or something. It's hard to believe that it's really needed?
Re: upper shock hardware [Re: RoadRunnerJD] #1000130
05/26/11 09:57 PM
05/26/11 09:57 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You can't use a lock nut because the stud would turn on the shock when installing the nut. So they use the lock nut to lock the nut on.
Re: upper shock hardware [Re: Challenger 1] #1000131
05/26/11 11:20 PM
05/26/11 11:20 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I found two stamped nuts like that in my dads bolt bins. They were too large to screw onto the brake booster studs. They do screw onto the shock though. I suppose they could be the origonal ones for the car.
So you're saying that the open part of the nut goes down, twards the other nut?
Re: upper shock hardware [Re: burdar] #1000132
05/27/11 01:06 AM
05/27/11 01:06 AM
Warrenton, VA
Warrenton, VA
The open part goes up.
Re: upper shock hardware [Re: RoadRunnerJD] #1000133
05/27/11 07:54 AM
05/27/11 07:54 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
correct, it's essentially a jam nut
Re: upper shock hardware [Re: gtx6970] #1000134
05/27/11 09:37 AM
05/27/11 09:37 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
That's what I thought but when he said it goes on upside down I was confused. Thanks
Re: upper shock hardware [Re: burdar] #1000135
05/28/11 03:09 PM
05/28/11 03:09 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
My memory is getting really bad but I don't remember the sheet metal lock nuts on assembly line front shocks just on replacements like Monroe.
.... but I would make sure. I have some NOS shocks and I'll check the hardware bags.
Re: upper shock hardware [Re: 52savoy] #1000136
05/29/11 04:51 PM
05/29/11 04:51 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
My NOS hardware bag didn't have them
Re: upper shock hardware [Re: Morty426] #1000137
05/29/11 11:43 PM
05/29/11 11:43 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
While they were probably specified to be there from the factory, I have seen few original cars with them. I'm sure the line workers threw them in the trash as it was one more step.
Having said that, I have documented them from 67-71 on all bodies. Here is an untouched 68 Coronet, notice the smaller 68 style washer not currently available.
Re: upper shock hardware [Re: Paul Jacobs] #1000138
05/29/11 11:50 PM
05/29/11 11:50 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Is that red paint on the tip only or the whole shock because I've never seen red production shocks. That would add even more confusion to shock colors.
Speaking of shocks..has anyone decifered(charted) the ORIFLOW numbers to correspond to the build sheets? I have a small collection of shocks but no way of knowing what models they fit. Most of the P/Ns are missing from the boxes.
Re: upper shock hardware [Re: 52savoy] #1000139
05/30/11 12:38 AM
05/30/11 12:38 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
That is mearly a paint dab designating it as a light duty shock, as compared to a blue dab that would indicate heavy duty. It was simply a quick reference for the line worker much the same as the leaf spring and torsion bar markings. All factory shocks from the era I speak of were black.
I have researched the builds sheets and compared them to the actual parts fpund on cars. They are often 1 number off (part number vs casting number) and Galens White Books goes along with this finding.
Re: upper shock hardware [Re: Paul Jacobs] #1000140
05/30/11 01:28 AM
05/30/11 01:28 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
The shocks seem to be the exception to the rule. The last 2 numbers stamped on the shock, should match the 2 numbers printed on the build sheet.
Th part number on the box, very rarely matchs the part number stamped on the shock. In fact, the part number on the box may represent many different stamped shock numbers.
Re: upper shock hardware [Re: Snoopy] #1000141
05/31/11 02:27 AM
05/31/11 02:27 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
and that's where the problem lies... With all the research over everything mopar you would think by now someone(with resources) sorted out the shock dilemma and made a reference chart.
Re: upper shock hardware [Re: Paul Jacobs] #1000142
05/31/11 01:39 PM
05/31/11 01:39 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Paul - I have seen the two different sizes used with no rhyme nor reason on various years...different vendors maybe? I have also seen those lock nuts installed upside down on a few original cars..... but hollow side up would be the proper engineering intent. The Guru's book shows a lot of cross-referenced shock numbers....most of them look correct
